March 4, 2019, 15:28 |
Boundary layer thickness of cylinder
Joanna Pazdur
Rep Power: 7 |
I am simulating air flow past cylinder and I wanted to calculate analytically the boundary layer thickness, just to compare it with what I got from Fluent. So I found this formula: δ ≈ 4,91√(νx/u) but I read it is applicable for flat plates. So my question is: can I apply this formula to a cylinder? And if yes, then my second question is: does x in the formula refer to the distance along the surface of the cylinder ex. half the circumference or rather the distance "across" the cylinder (I mean straight in the direction of the flow) ex. diameter? I would be very grateful for any reply! Regards, Asia |
March 4, 2019, 15:43 |
Filippo Maria Denaro
Rep Power: 71 |
No, you cannot use the BL theory over a flat plate
March 4, 2019, 15:58 |
Joanna Pazdur
Rep Power: 7 |
You meant I cannot apply it to the cylinder, didn't you? Cuz you wrote "flat plate" and my question is about cylinder.
Anyway, thanks for reply! |
March 4, 2019, 16:04 |
Rep Power: 71 |
March 4, 2019, 16:11 |
Joanna Pazdur
Rep Power: 7 |
Is there any formula for the boundary layer thickness in the case of a cylinder then?
March 4, 2019, 21:52 |
Rep Power: 18 |
Do a search for Thwaites method.
boundary layer thickness, cylinder flow |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
Questions about Boundary Layer Thickness and Turbulence Models | famerfamer | STAR-CCM+ | 3 | July 12, 2012 09:47 |
