March 24, 2019, 11:07 |
Convergence Study
anonymous
Rep Power: 8 |
Hey everyone I am quite new to CFD and I am currently undergoing a project where I am required to carry out a convergence study. I want to make sure that parameters (heat transfer, velocity) are steady within my domain.
I have a questions and that is, does my choice of convergence points in my model have to be located at a node or can it be any point of interest inside the domain? For example to ensure heat transfer near the wall is steady over several hundred iterations, I can pick my convergence point 5mm away from the wall on a node in my first mesh. Redesigning the mesh to save on computational time, this point no longer is represented by a node. Would this have any impact? I am a little unsure about this as i believe the whole domain is calculated by interpolation techniques between nodes, so this shouldn't have any impact on my mesh convergence study. If you have any knowledge you are willing to share much appreciated. Thank you in advance, asda3D |
March 24, 2019, 11:42 |
Filippo Maria Denaro
Rep Power: 71 |
The convergence to the steady state requires that time derivatives in all the computational points tend to vanish. You need to check this condition (numerical time derivatives< threshold) everywhere in the cells.
March 24, 2019, 16:02 |
anonymous
Rep Power: 8 |
Thank you for the reply, I do understand that. Overall convergence is easily identifiable on CFD software, however even if the global parameters have converged there are points of interest where the physics of the flow is very disruptive and may not have converged. This is why points of interest need to be accounted for as well.
My questions is, do these specific monitoring points have to be located on the mesh in order to show convergence or is it OK for the points to lie off the mesh. Would this impact the points convergence? |
March 24, 2019, 16:26 |
#4 | |
Rep Power: 71 |
It makes no sense to use interpolation to monitor points that are not those wherein the equations are numerically solved. If the derivatives in the computational nodes are telling you that the steady state is reached you get the converged solution. |
March 25, 2019, 07:36 |
#5 | |
Rep Power: 13 |
March 25, 2019, 08:18 |
Lucky
Rep Power: 66 |
Convergence is not a binary converged/not-converged decision nor is it an objective decision.
There is the direct way of checking that time derivatives is less than a threshold in every cell. There is also the indirect way of checking other calculated parameters (like interpolated values). Then someone makes the subjective value call or whether it is good enough or not. |
Grid Convergence Index (GCI) for study involving five grids | RobV | Visualization & Post-Processing | 0 | December 30, 2016 06:22 |
[ANSYS Meshing] Grid convergence study | AS_Aero | ANSYS Meshing & Geometry | 1 | June 7, 2013 04:29 |
[ICEM] Grid Convergence Index study for a hybrid mesh | j_h_86 | ANSYS Meshing & Geometry | 2 | December 6, 2012 11:45 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 10:55 |
convergence/ advise for permeability study | CFDnewbie | CFX | 0 | August 21, 2005 02:50 |
