Difference betwen law of wall and Blasius boundary layer
Like Tree1Likes
  • 1 Post By FMDenaro
Old   May 21, 2019, 21:59
Default Difference betwen law of wall and Blasius boundary layer
CFD USER
CFD_10 is on a distinguished road
I have some questions regarding following concepts:
The law of wall, where
u^+ = f(y^+)
which is described here: https://en.wikipedia.org/wiki/Law_of_the_wall
and the velocity profile of the boundary layer ,e.g: Blasius velocity profile, given here: https://en.wikipedia.org/wiki/Blasius_boundary_layer
1. What is the difference between these two concepts?
2. If the law of wall is universal ,then why not using this law for boundary layer?
3. Is the Blasius velocity profile a special case of the law of wall?
What is the difference/relation between these two velocity profiles?
Thanks
CFD_10 is offline   Reply With Quote
Old   May 22, 2019, 01:50
veerappan
veera is on a distinguished road
especially blasious is not applicable for laminar flow
and law of the wall applicable to the turbulent one
veera is offline   Reply With Quote
Old   May 22, 2019, 02:48
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
The velocity u+ stands for the statistically steady velocity in a fully developed confined turbulent field.
Blasius solution describes the spatial developing steady BL in a laminar flow.
FMDenaro is offline   Reply With Quote
Old   May 22, 2019, 09:43
CFD USER
Could you please explain in more details?
Old   May 22, 2019, 09:51
CFD USER
Another question is:
In the law of wall, the boundary layer is devided to 3 sublayers: viscous sublayer, buffer sublayer, and the logarithmic sublayer.
But in the boundary layer theory I've never seen this terms.
Please give details (I cannot understand in two sentences, very detailed answers are very welcome!)
Old   May 22, 2019, 10:33
Again, you are comparing the laminar theory to the turbulence theory. There are fundamental differences in the working model. That is a topic of basic fluid dynamics courses and can be found in any good textbook (one is Kundu).
lcarasik likes this.
Old   May 22, 2019, 10:47
Lucky
It would be more conducive if you tell us what you already do know about the law of the wall versus the Blasius solution.
As already mentioned, the law of the wall deals with turbulent boundary layers and Blasius laminar boundary layers.
You'll almost never see these come up if you study only laminar boundary layer theory. Turbulent boundary layers have these characteristic regimes and it takes really an entire course to explain it in detail. Again, tell us what you already know and we can fill in the holes. Otherwise, pick up a book on turbulence.
Turbulent boundary layers are divided into outer and inner layers and the inner layer is further sub-divided into the (linear/viscous/laminar) layer, buffer layer, and logarithm layer. They are divided because the turbulent characteristics in these regions are different. Each region has different solution forms. In laminar boundary layers there is no turbulence and that's why you never see these terms there and the Blasius equation describes the entire velocity profile.
LuckyTran is online now   Reply With Quote
Old   May 22, 2019, 13:31
CFD USER
Thank you very much for the explanation.
I have read the book of white "Fluid mechanics" both topics can be found but I cannot find any comparison between the two.
Old   May 22, 2019, 13:42
There is no comparison because the Blasius theory provides a solution for the Prandtl equations while the u+ velocity is the velocity for the statistically averaged NSE.
In a fully developed turbulence field you have the viscous sublayer, a very small region close to the wall (y+<5) where u+=y+ tends towards the laminar solution.
Old   May 22, 2019, 23:23
Smile
CFD USER
Thank you
Bump in flat plate boundary layer DCK STAR-CCM+ 2 July 23, 2015 01:55
Boundary Layer of Laminar Flow over a Flat Plate Blasius_Pohlhausen_Crocco Main CFD Forum 12 September 30, 2013 17:35
Boundary Layer Profile anti-random FLUENT 0 September 18, 2012 04:37
Correct way to generate grids for boundary layer quarkz Main CFD Forum 5 November 23, 2006 23:25
boundary layer jj Main CFD Forum 7 August 11, 2006 04:00
