November 17, 2021, 08:45 |
tube
Nikolakis
Rep Power: 5 |
Hello i want to analyse a flow in a tube with heat flux on the walls. I separated the tube in two parts so i get a finer mesh on the part before the flow develops fully. So i get a weird temperature drop on 0,4 meters the point the two parts separate (photo = https://imgur.com/a/AFOaIOZ) noted that i used share topology for the two parts. This is my mesh https://imgur.com/a/I6HIDEd
https://imgur.com/a/XUvC5pz any suggestions? I assumpt that the flow develops fully at 10*D=0,3 m how can i show the boundary layer of velocity and thermal in contours? |
Defining Boundary Condition of Simulation of Shell and Tube Heat Exchanger ? | miftahazhar | FLUENT | 0 | June 26, 2019 10:34 |
Moving solid in a tube | D2Net15 | CFX | 3 | January 14, 2019 11:12 |
double tube heat exchanger | mehyan | CFX | 4 | December 8, 2015 16:44 |
[OpenFOAM] Tube filter in Paraview | werweisswas | ParaView | 0 | December 10, 2012 06:18 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
