What are the differences between these different forms of equation? |
June 29, 2019, 10:18 |
Mandeep Shetty
Rep Power: 10 |
What are the differences between Conservative differential form, Non conservative differential form, Conservative Integral form and Non conservative integral form of differential equations?I know that there are a lot of different post on 'conservative vs non conservative form' and ' differential vs integral form' but from what I have read conservative and non conservative form of the governing equations also have differential and integral type. Where are these different types of equations applied and what are the advantages and disadvantages of one over the other ?
June 29, 2019, 12:09 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
There are a lot of discussions about this topic. I suggest also to have a reading to the Chap.1 of the Hirsch textbook that addresses the topic in a clear way. Briefly, I use the mass equation to address the differences: - Integral conservative form d/dt Int [V] rho dV + Int [S] n.v rho dS =0 - differential conservative form d rho/dt + Div(v rho) =0 - differential quasi-linear (non conservative) form d rho/dt + v.Grad rho + rho Div(v)=0 Note that conservation property is valid for the physical variables that can be conserved, that is mass, momentum and total energy. For example, you can write the integral form of the kinetic energy equation but this variable is never conserved in the general case. |
June 29, 2019, 14:07 |
#3 | |
Mandeep Shetty
Rep Power: 10 |
June 29, 2019, 14:26 |
Rep Power: 71 |
"every explanation of conservative form is using the differential conservative form and never the integral form. "
who told you that?? I addressed the textbook of Hirsch but you can also see the chapters in the Peric and Ferziger textbook, as well as other CFD books. And in a more general fluid mechanics framework, the conservation equations are always derived from the Reynolds transport theorem that is by definition in integral form. |
June 30, 2019, 04:21 |
#5 | |
Mandeep Shetty
Rep Power: 10 |
June 30, 2019, 04:30 |
#6 | |
Rep Power: 71 |
It can be demonstrate that the volume integral formulation for the conservation equation is a special case (in the sense of the use of specific test function) of weak formulation. You can write other weak formulations that do not correspond to the conservation laws. Note that in case of the presence of second order derivatives (as in the diffusive terms) the integral formulation still requires the continuity for the first derivative. |
July 2, 2019, 05:43 |
#7 | |
AGN
Rep Power: 14 |
Divergence can make the integral more accurate and easy on irregular domains. Could you give me a better reason or explanation other than that for an integral form to be a conservative scheme? Why can't differential form can't be conservative? It is also satisfying the governing equation! In some special cases, even higher order differential and higher order integral form are reduced to the same formulation! |
July 2, 2019, 07:08 |
#8 | |
Rep Power: 71 |
See my answer in the other post. |
governing equations |
Adding diffusion term to interFoam transport equation | Gearb0x | OpenFOAM Programming & Development | 3 | February 14, 2023 04:16 |
Problem with Velocity Poisson Equation and Vector Potential Poisson Equation | mykkujinu2201 | Main CFD Forum | 1 | August 12, 2017 13:15 |
Solving Equation and Matrix declaration (differences) | Tobi | OpenFOAM Programming & Development | 6 | September 10, 2014 10:39 |
How to? Extra term in k-e equation. Implicit-Explicit | be_inspired | OpenFOAM Programming & Development | 1 | March 19, 2013 10:50 |
conservative/non-conservative forms of NS equation | Ishaq | Main CFD Forum | 0 | June 20, 2006 01:47 |
