July 12, 2019, 09:41 |
non orthogonal 2d grid
hajo jllon
Rep Power: 6 |
Hey there
I have a nozzle like the image the vertical grid is called r and the grid along each streamline is called m as a meridional grid I dont know what to do to compute derivative of some parameter along m direcion with backward difference method... i mean what should be the denominator ? |
July 12, 2019, 16:59 |
Filippo Maria Denaro
Rep Power: 71 |
Just consider the transformation from the physical (csi,eta) to the computational domain (x,y). In your case csi=x, you have only to consider the transformation along the vertical direction given by the law eta(csi).
July 13, 2019, 13:35 |
hajo jllon
Rep Power: 6 |
thanks
so you mean say for taking derivative of like function F along each stream line dFdm will be (Fi-F(i-1))/(x(i)-x(i-1) ? |
July 18, 2019, 16:40 |
Grid
Selig
Rep Power: 10 |
From my experience with curvilinear grid (albeit still learning), you should calculate the metrics using central schemes. In this case
(F(i+1) - F(I-1))/(2*dx)) |
Dynamic Mesh resulting in Curved Grid Lines | adubois | FLUENT | 3 | April 17, 2014 10:06 |
PBC breaks down, is there a grid check tool? | gerritgroot | SU2 | 8 | June 13, 2013 18:24 |
Obtain Geometry Data from a Grid File in CFX 10.0 | ARJUN | CFX | 2 | August 17, 2006 07:20 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 16:43 |
Numerical methods for discontinuous grid interfaces? | Hansong Hang | Main CFD Forum | 12 | September 16, 1998 22:26 |
