Droplet free falling
Old   September 9, 2019, 06:41
Default Droplet free falling
X
mcfdma is on a distinguished road
Hi.
Droplet + Electrohydrodynamic
I am simulating a free-falling droplet which passes through a uniform electric field (parallel plates). When I have a coarse mesh, it seems like the droplet deforms and there is a spray production (what is supposed to occur according to experiment). However, when I refine the mesh, I do not get a spray and the droplet shape/formation is very different.
mcfdma is offline   Reply With Quote
Old   September 9, 2019, 06:44
X
This is a snapshot.
Left - coarse mesh
Right - refined
Old   September 9, 2019, 06:57
Moreza7 is on a distinguished road
Originally Posted by mmalik View Post
Hi.
Your simulation must be mesh independent, so its obvious that the case with coarse mesh is not reliable.
Does your simulation become mesh independent after a specific number of nodes? If yes, it maybe something wrong with your boundary conditions or fields that you set.
Do you use your own code or special software?
Moreza7 is offline   Reply With Quote
Old   September 9, 2019, 07:16
X
Thanks for the reply.
I am new to OF. How do you check mesh independence after specific number of nodes?I am working on mesh independence (which is why I am refining it). However, as I refine, I do not get the spray, which I should get. So refining further is pointless, I think.
My BCs
alpha.water
    object      alpha1;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    atmosphere
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    outlet
        type            zeroGradient;
    defaultFaces
        type            empty;
rhoE (charge density)
    object      rhoE;
dimensions      [0 -3 1 0 0 1 0];
boundaryField
    atmosphere
        type            zeroGradient;
    inlet
        type            zeroGradient;
    outlet
        type            zeroGradient;
    frontAndBack
        type            empty;
U
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    axis
        type            empty;
    inlet
        type            fixedValue;
        value           uniform (0 0 0);
    atmosphere
        type            pressureInletOutletVelocity;
    outlet
        type            fixedValue;
    front
        type            wedge;
    back
        type            wedge;
Ue (electric potential)
    object      gamma;
dimensions      [1 2 -3 0 0 -1 0];
boundaryField
    inlet
        type            fixedValue;
        value           uniform 0;
    atmosphere
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 3.6e3;
    defaultFaces
        type            empty;
setFieldsDict
    object      setFieldsDict;
defaultFieldValues
    volScalarFieldValue alpha.water 0
regions
    sphereToCell
       centre (0.7e-3 9.8875e-3 0.1e-3);
       radius 1.7e-4;
       fieldValues
            volScalarFieldValue alpha.water 1
            volScalarFieldValue rhoE 0.0478
        volVectorFieldValue U (0 -5 0)
In regards to the code, yes. It is a modified interfoam solver which includes electric equation. I am using OF2.3.1
Old   September 29, 2020, 16:33
Smyrna is on a distinguished road
Hi
As far as I know, refining mesh will not always provide you a better solution since CSF. In VOF models the spurious currents are forming around the droplet interface. I am not saying do not refine your mesh please check this paper to get a better understanding of the phenomenon.
https://iopscience.iop.org/article/1...5/1/014016/pdf
Smyrna is offline   Reply With Quote
droplet ionization, electrodynamics, hydrodynamics, interfoam bubble
modeling droplet falling to the bottom problem TimLim FLOW-3D 1 June 15, 2018 17:03
Falling Droplet using InterFoam cosbergel OpenFOAM Running, Solving & CFD 5 May 16, 2018 05:21
Water droplet falling in humid air koslv FLUENT 0 April 19, 2018 00:06
droplet falling - VOF bohis FLUENT 1 July 10, 2013 04:28
sphere falling down droplet naderafshar FLUENT 1 December 24, 2011 10:30
