November 21, 2022, 23:11 |
Other Implicit method to compare with TDMA ?
Hello everyone,
I have solved my energy equation based on TDMA (Tridiagonal Matrix) implicit method. I would like to compare my case with any other implicit method ? Kindly share any suggestions ? Thank you |
November 22, 2022, 08:44 |
Rep Power: 18 |
Strictly speaking TDMA is just a solution technique for solving a system of linear equations, not an implicit method. If you are looking for other linear system solvers then you can consider Guass-Seidel, Jacobi, GM-RES, ... Just look in any book on numerical techniques for linear systems.
Physical Reason for stability of Implicit Schemes? | radhakrishnan | Main CFD Forum | 26 | October 3, 2023 22:05 |
Harmonic balance method for calculating multi-stage turbines | HIT19B902072 | SU2 | 2 | April 24, 2022 01:31 |
Ferziger and Peric method on implicit pressure and velcity coupling | Hooman | Main CFD Forum | 0 | July 15, 2010 06:49 |
Code for most powerfull FDV Method | D.S.Nasan | Main CFD Forum | 6 | September 4, 2008 02:08 |
Help about the preconditioner in gmres method | Dan Gao | Main CFD Forum | 3 | July 5, 2008 01:18 |
