periodic Boundary Condition for unstructured grid
Old   June 13, 2000, 21:24
Default periodic Boundary Condition for unstructured grid
MLJ
If we use unstructured grids to do Large Eddy Simulation, how can we impose the periodic boundary conditions for certain flow field boundaries? Any suggestion?
Old   June 14, 2000, 17:13
Default Re: periodic Boundary Condition for unstructured grid
John C. Chien
(1). It is easier if you define the boundary mesh of the periodic condition by either a linear translation or a rotation. (2). In this way, the boundary itself will be identical to each other. (3). Then the condition itself simply says that the flow variable will be identical. That is PHI(translated, or rotated location)=PHI(corresponding original location). (4). So, the mesh distribution along the periodic boundary (or on the periodic boundary surface) must wait until the corresponding original boundary mesh is completed. In 2-D, you can only specify mesh distribution along the three edges (say inlet, exit, one of the periodic boundary). In 3-D , you can only specify 5 out of 6 boundary surfaces. The second periodic boundary mesh must be identical to the first one by translation of rotation.(5). You can also write your interpolation routines along the periodic boundary, if the meshes along the boundary are not identical to each other.
Old   June 16, 2000, 05:57
Aldo Bonfiglioli
International Journal for Numerical Methods in Fluids Volume 18, Issue 12 30 June 1994 Pages 1153-1165
On the implementation of symmetric and antisymmetric periodic boundary conditions for incompressible flow
Segal, Guus; Vuik, Kees; Kassels, Kees
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
translational periodic boundary condition Rola Afify FLUENT 2 September 12, 2006 08:39
Periodic Boundary Condition Swapnil CFX 1 December 17, 2002 21:59
Multiblock grid, interface Boundary condition Nandu CFX 2 August 6, 2002 05:07
