prescribing pressure Boundary Conditions IPCS |
February 12, 2020, 04:12 |
Jack Tattersall
Rep Power: 6 |
Hello all,
I have a very basic model of a pipe which is solved by the IPCS method. I want to have it pressure driven, however, I'm not sure how to set the BCs. My question basically is: if I want to model flow through a pipe and have it pressure driven, so I dont want to prescribe a flow. How can I implement this with when the NS equations are solved through the IPCS method. I dont know what BC to prescribe in the tentative velocity step or how this actually works. Thanks in advance! Cheers, Jack |
February 12, 2020, 06:56 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
You should provide more details. Are you solving an incompressible flow problem, right? IPCS stands for incremental pressure correction I suppose. If you have periodic condition in streamwise direction you can simply set a pressure forcing term in the momentum equation, the residual pressure is solved by the Poisson equation with periodic BCs. The flow rate is determined by the forcing term. If you have an inflow/outflow sections you could set the pressure at inflow and outflow. If you don't know the flow rate and the inlet velocity profile that is the only way you can work. |
boundary conditions, ipcs, pressure correction, pressure driven flow, splitting scheme |
Pressure inlet & pressure outlet Boundary conditions | aakash hassan | FLUENT | 5 | August 11, 2018 05:11 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
