March 1, 2020, 01:03 |
Heat flux boundary condition
Rep Power: 10 |
Hello everyone,
I am simulating airflow in a room with a block heater using a CFD code. Does anyone know how to implement heat flux B.C of the block heater in a finite difference CFD code? In energy equation (I mean temperature transport equation), temperature B.C. can be easily applied to the code however applying heat flux B.C. is a little tricky. Can I use T(i)=q''/h+T(i-1) to implement the boundary condition in the fluid domain (T(i) is the temperature on the surface of the heater and shall be computed, T(i-1) is the temperature of adjacent node within the fluid)? If yes, how can I determine the h coefficient? Any help or comment is appropriated. Mike |
March 1, 2020, 03:52 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
On a boundary (for example a wall) you set the continuity between the conduction in the solid (flux q) and the heat flux in the fluid (-k Grad T) along the normal to the boundary. That is -k dT/dn = q you see that q must be known from the physics of your problem and k is known from the fluid. Then, you have to discretize dT/dn using an asymmetric FD formula (I strongly suggest to use at least a second order formula) that gives the T at the wall as a function of the internal layer and the condition q. |
March 1, 2020, 04:03 |
#3 | |
Rep Power: 10 |
As I mentioned for obtaining the wall temperature, q=h(delta T) equation can be used. However the convection heat transfer coefficient (h) is unknown and that's my problem. |
March 1, 2020, 04:32 |
#4 | |
Rep Power: 71 |
No, that depends on the problem you are considering. If you are studying a CHT problem then yes, the temperature field in fluid and solid must be solved together. Conversely, in a classical heat transfer study the heat flux q applied at a wall is a known condition, that is you do not need at all to prescribe h but only the flux. This is a classical non homogenous Neumann condition that is expressed only in terms of the normal derivative of the temperature on the boundary. |
March 2, 2020, 16:04 |
#5 | |
Pedro Costa
Rep Power: 8 |
Since you are doing CFD, it doesn't make sense to lump convective effects into a heat transfer coefficient h. You are already resolving convective effects from 'first-principles' in the CFD code, since you solve for a velocity field! So, for instance, if you use central finite differences, at the boundary i=0 you could have something like: (T(1)-t(0))/dx = q'' -> T(0) = q''dx+T(1). But this BC is not centered at the boundary, so it may be nicer to use second-order one-sided differences as suggested above, and you have for constant grid spacing:T(0) = (-2*q''dx+4*T(1)-T(2))/3 [google is your friend for confirming this result ]. I hope this helps! |
cfd, finite difference, heat flux |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
