Which transport equation, which scheme, which model??? |
March 5, 2020, 06:59 |
Masih
Rep Power: 6 |
My project is related to filling a tank with hydrogen. The inlet mass flow is 1 kg/s and the the tank initially has 1 kg hydrogen inside. So, technically after 5 seconds, the mass inside the tank should reach to 6 kg. First, I used Peng-Robinson equations and after checking the final result by using integrate variables in paraview I found out the final mass was much less than I expected. Then, I changed the transport equations to perfect gas. In that case, the mass inside the tank reached to 9 kg. I have tried different schemes including linear, upwind and linearUpwind schemes and I also tried both kEpsilon and kOmeqaSST models but none of them influenced the final result that much. I am using openfoam 5 and the rhoCentralFoam is the solver. What is the problem do you think and how can i deal with it? Best regrads, Masih Mojarrad |
Adding diffusion term to interFoam transport equation | Gearb0x | OpenFOAM Programming & Development | 3 | February 14, 2023 04:16 |
Solving User-defined Scalar Transport Equation properly | meepokman | Fluent UDF and Scheme Programming | 0 | July 10, 2018 07:57 |
Zero equation Vs k-epsilon model | CFD_smukthi | Main CFD Forum | 1 | December 3, 2016 16:57 |
Adding transport equation to radiation model | kirankarki | OpenFOAM | 0 | October 26, 2010 16:10 |
