March 16, 2020, 15:17 |
Why does the checkMesh fail after using arc
Masih
Rep Power: 6 |
I am trying to convert a cubic to cylinder. Before starting using arc in the edges, everything was fine. Then, I tried to curve a side. After implementing blockMesh, I have not got any error but after command "checkMesh", I got an error saying that "failed 1 mesh checks". I checked paraview and everything was exactly what I expected. I also ran a simulation and it seemed that it worked properly. So, I wonder why I got this error and how I can deal with that? I just found something new which may help. I switched to 2D and the problem was gone. So what can I do to solve this problem in 3D? Best regards, Masih |
March 16, 2020, 17:24 |
Lucky
Rep Power: 66 |
What was the check that did not pass? Check the output of checkMesh. If the check passes, there will be an OK. Among other things, checkMesh looks for things like max cell aspect ratio, orthogonality, skewness, etc. These checks can fail and the mesh can still be valid. Actually, almost all the checks can fail and the mesh can still "look as expected" depending on the user's expectations.
March 17, 2020, 05:10 |
Masih
Rep Power: 6 |
Thanks a lot for your reply. I think the check passed. Just to be sure, let me show you the output:
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 907184 faces: 2612365 internal faces: 2505935 cells: 853050 faces per cell: 6 boundary patches: 1 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 853050 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 3 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 with 211500 cells to cellSet region0 <<Writing region 1 with 211500 cells to cellSet region1 <<Writing region 2 with 430050 cells to cellSet region2 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology defaultFaces 106430 106436 ok (closed singly connected) Checking geometry... Overall domain bounding box (0 0 0) (11 1.02425 0.8485) Mesh has 0 geometric (non-empty/wedge) directions (0 0 0) Mesh has 0 solution (non-empty) directions (0 0 0) ***Number of edges not aligned with or perpendicular to non-empty directions: 410640 <<Writing 226088 points on non-aligned edges to set nonAlignedEdges Boundary openness (-8.10481989877876e-19 -1.25922383370715e-14 2.32556553464854e-16) OK. Max cell openness = 3.28098648589246e-16 OK. Max aspect ratio = -1 OK. Minimum face area = 3.02749999999951e-05. Maximum face area = 0.00327659574468175. Face area magnitudes OK. Min volume = 1.41712765957277e-06. Max volume = 2.76181100172144e-05. Total volume = 9.04829154912669. Cell volumes OK. Mesh non-orthogonality Max: 41.9131329708367 average: 5.61442986760273 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.65565039524076 OK. Coupled point location match (average 0) OK. Failed 1 mesh checks. End While before I wanted to curve the side, the output had been like: Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 907184 faces: 2612365 internal faces: 2505935 cells: 853050 faces per cell: 6 boundary patches: 1 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 853050 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 3 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 with 211500 cells to cellSet region0 <<Writing region 1 with 211500 cells to cellSet region1 <<Writing region 2 with 430050 cells to cellSet region2 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology defaultFaces 106430 106436 ok (closed singly connected) Checking geometry... Overall domain bounding box (0 0 0) (11 0.8485 0.8485) Mesh has 0 geometric (non-empty/wedge) directions (0 0 0) Mesh has 0 solution (non-empty) directions (0 0 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (8.80555669309502e-20 3.12084741810656e-15 2.36338470594129e-16) OK. Max cell openness = 1.78516385030031e-16 OK. Max aspect ratio = -1 OK. Minimum face area = 3.02749999999951e-05. Maximum face area = 0.00327659574468175. Face area magnitudes OK. Min volume = 1.41712765957277e-06. Max volume = 1.71776117021312e-05. Total volume = 7.91947474998802. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.03595532552006e-13 OK. Coupled point location match (average 0) OK. Mesh OK. End So what do you think? Can I keep on my simulation? Thanks in advance for your time and consideration Best regards Masih |
March 17, 2020, 07:16 |
#4 | |
Lucky
Rep Power: 66 |
The check that failed is:
This one you cannot ignore but is easily fixable. This happens when you have faces (actually edges of faces) that don't belong to anything. And this can easily happen when you forget to assign faces to patches in the blockMeshDict. If you plot your mesh for the cylindrical case in paraview, you'll probably see a group called defaultFaces which will normally be empty because they would normally be assigned to a patch with names like mywalltop, yourinlet, somebodysoutlet, etc. Go fix your blockMeshDict Last edited by LuckyTran; March 17, 2020 at 09:34. |
March 17, 2020, 07:59 |
Masih
Rep Power: 6 |
Well, I think I had done what you said. First, I tried to curve the top wall which belongs to upperWall in blockMeshDict. There are some default faces in my case because there are some internal faces. So, I do not really understand where this error comes from. I attached the blockMeshDict.
March 17, 2020, 10:37 |
Lucky
Rep Power: 66 |
The problem is not your curving arc but your blocks which ends up creating internal patches that are not being automatically removed.
The face vertices of the intersections between your blocks are not identical because you have 1 block intersecting 3 blocks (e.g. Top Box and the 3 middle blocks and Bottom Box and the 3 middle boxes). There are 8 such faces (1 big face on the top box, 1 big face on the bottom box, and the 6 faces that are coincide with them) that ends up creating two groups. You can either assign all 8 of them to patches and merge them using th mergePatchPairs option at the end of the blockMeshDict or you can split up your top and bottom boxes into 3 smaller boxes the same way you have one the middle box. Then they will be automatically merged by the algorithm. Once you fix this, both of the mesh checks should pass. |
[blockMesh] Openfoam: Meshing, where do my defaultFaces come from | syntex | OpenFOAM Meshing & Mesh Conversion | 19 | December 10, 2018 07:21 |
settlingFoam unstable? | bendel_boy | OpenFOAM Running, Solving & CFD | 38 | July 8, 2016 05:07 |
[blockMesh] Another cylinder question | bendel_boy | OpenFOAM Meshing & Mesh Conversion | 5 | January 6, 2015 05:09 |
[Other] mergeMatchPairs with arcs | vainilreb | OpenFOAM Meshing & Mesh Conversion | 1 | August 5, 2013 08:11 |
[blockMesh] apparently the mesh doesn't want to be created in one direction | Maxime Thomas | OpenFOAM Meshing & Mesh Conversion | 1 | August 18, 2012 06:05 |
