Accessing a private member from a different namespace and class to a template class
Old   April 5, 2020, 13:37
Default Accessing a private member from a different namespace and class to a template class
pankaj sharma
pankajadgjmp is on a distinguished road
I am trying to access a private member from a class with radiation namespace, to a template class in Foam namespace. I tried replicating a similar (own c++ code ) and simple test code with multiple namespace and classes and was successful. But the moment I want to use that same method in OpenFOAM I get errors.
did anyone came across a similar problem or have a solution please help.
The error says "multiple definition of `Foam::radiation::accessd_(Foam::radiation:Eradi ativeIntensityRay)' "..
Although the error might not make sense without the program but it is something like this
friend int accessd_(DEradiativeIntensityRay obj);
}; // End of class
//DEradiativeIntensityRay user; //object to access d_
int accessd_(DEradiativeIntensityRay obj) // the line of error
int private_{0};
private_ = obj.test;
Info<<" The value of private is "<<private_ <<endl;
return private_;
pankajadgjmp is offline   Reply With Quote
Old   April 6, 2020, 10:36
Tom-Robin Teschner
t.teschner is on a distinguished road
well, going by your incomplete code snippets it is virtually impossible to diagnose the problem. could you share the code which is working so that it is clear what you are trying to achieve? sometimes the approach may not be the best and there is a better solution available, maybe that is the case here?!
When you want to access private members, you would almost always want to do that through a getter method. I am not sure what is holding you back in this case to use a function of the form
int DEradiativeIntensityRay::get() { return test; }
(maybe you don't want to recompile the OpenFOAM codebase?!), so that information would help as well.
"Friends" don't really work well in an object orientated approach, much like a goto statement (at least in my opinion), but there are always legitimate reasons to do that, so a code example would help here.
t.teschner is offline   Reply With Quote
c++, cfd, error, openfoam, programing
BasicTurbulenceModel class declaration in OpenFOAM 6 rod_petrone OpenFOAM Programming & Development 3 April 15, 2019 08:27
Adding new member function to GidaspowErgunWenYu.C of dragModel kiang OpenFOAM Programming & Development 0 June 21, 2017 05:23
Calculation of rotational equation of motion using DPMFoam ansubru OpenFOAM Programming & Development 4 November 1, 2014 11:57
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 11:40
member function [value()] of dimensioned<Type> class sblee1977 OpenFOAM Programming & Development 2 November 9, 2010 03:52
