Momemtum (DMST) model is not converging at high TSR for VAWTs
Old   May 2, 2020, 05:27
Question Momemtum (DMST) model is not converging at high TSR for VAWTs
Amin A. Mohammed
amin013 is on a distinguished road
Dear all,
I'm facing convergence issue for solving the axis induction factor using double multiple streamtube model at high tip speed ratio (TSR), when the rotor solidity is a bit high, for vertical axis wind turbines. The solution is iterative.
It is agreed that, momentum momentum models in general, have some convergence issues at high rotor solidities and/or high TSRs. However, I heard that, one can introduce some damping effect to get the solution converge, or utilize some low pass filter for that purpose.
For example, the axial inducting factor is obtained from (iteratively):
a = 1/(1-F)
where F is a function of the airfoil characteristics and directly related to tangential and normal force coefficients.
Moreover a = Va/Vinf (the ratio of induced speed at the blade to the free stream velocity), initial guess a = 1, i.e. Va=Vinf.
Cheers
amin013 is offline   Reply With Quote
aerodynamic analysis, aerodynamic forces, vertical turbine ami, wind engineering
Recording very high temperatures in my model of micro combustion in porous inert medi Evnie1 FLUENT 0 April 23, 2019 01:40
How to model combustion in high speed flows anandraj FLUENT 1 December 18, 2008 10:10
High Reynolds Number Model Elaprolu Vishnuvardhnarao Main CFD Forum 0 July 11, 2005 07:11
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
high RE Turbulent model autofly Main CFD Forum 1 July 1, 2003 11:45
