Cooling Brake Simulation: A Motion Problem Between Two Solid Interfaces
Old   May 10, 2020, 12:03
Default Cooling Brake Simulation: A Motion Problem Between Two Solid Interfaces
SimulatorMaster's Avatar
Onur
SimulatorMaster is on a distinguished road
Hello there people of the internet;
Recently I have started a project on F1 Car brake simulation. The geometry can be seen below. The red/orange color represents the air domain (the inlet and pressure outlets respectively) while those two things to the right of the main body, which is the disc, are the calipers that will apply friction the the disc.
The continua for the solids are:
  • FSI-Fluid Structure Interaction
  • Finite Element Solid Energy
  • Solid Stress
  • Implicit Unsteady...
The fluid, on the other hand, has coupled energy and flow is turbulent and constant density. So far no errors given on the models.
The disc in the middle will be rotating at 2000 RPM while the calipers will apply pressure gradually slowing down the rotation; however, I cannot assign different motions to the calipers and the disc. (I assigned the same rotational motion to the fluid not sure if necessary) The error can be seen below. Apparently both systems must be in the same motion yet that's something I do not want.
My interfaces are all mapped-contact interfaces created by imprinting and making contact mode interfaces. Not exactly sure what I should be doing.
That being said, do I need to assign rotation to the fluid region or can I leave it be with the mapped interface?
SimulatorMaster is offline   Reply With Quote
Sliding mesh for translational relative motion between solid and fluid shashankmechguy FLUENT 2 April 12, 2024 17:27
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
External management of solid motion (using dynamicmesh) maxou1993 Main CFD Forum 0 July 28, 2015 11:37
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Disc brake simulation with solids Roland R CFX 4 June 13, 2012 08:52
