Y plus value requirement for no -slip wall condition |
May 20, 2020, 08:42 |
Rep Power: 6 |
Hello everyone
My question is very rudimentary. I want to simulate flow through a duct using CFD. I want to use k-e model with no-slip wall condition. what is the appropriate wall distance (y+) value required to perform such a condition ? From my understanding k-e model works for the condition 30<y+<300. But what happens when we use no-slip wall condition. The velocity gradient at the wall becomes zero. So what kind of y+ value is required? please let me know. Thank you |
May 20, 2020, 10:04 |
Lucky
Rep Power: 66 |
What software? What implementation? The devil is in the details...
This isn't a requirement for the k-epsilon model itself but a condition for a certain wall function which already implies a no-slip wall condition being used. The velocity gradient isn't 0. Zero gradient would be a slip wall. Look into whatever code you are using and figure out which implementation of k-epsilon you are using and which wall treatment you are using and come back with some more details. Either way, most likely you'll be targeting a very low y+<10 or a in the 30-300 range. |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Diameter varying slip condition on wall , 2d pipe flow | k.giannoko | OpenFOAM Pre-Processing | 0 | August 25, 2016 14:54 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 04:13 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
