Turbulent Velocity Scale and Turbulent Viscosity Ratio |
June 17, 2020, 12:38 |
MA
Rep Power: 6 |
Hi Everyone,
I am using K-Omega SST Model for an external aerodynamics (wind turbine) problem. For the initial conditions, I want to calculate the turbulent velocity scale and viscosity ratio. First, I used the reference: https://www.cfd-online.com/Wiki/Turb...ary_conditions However, the equations I used are taken from STARCCM+ Manual. While calculating for Turbulent Velocity Scale, I see that for turbulent length scale I need turbulent time scale and for turbulent time scale I need specific dissipation rate (omega) and for omega, again I need turbulent length scale as shown in the picture. This is confusing, how can I evaluate turbulence length scale to get the turbulent velocity scale in the end? Secondly, for turbulence viscosity ratio, I checked with above link it is "Mu_t/Mu" but I don't know how to get Mu_t and whether "Mu" in the denominator is dynamic viscosity? Thanks for your time; |
June 17, 2020, 12:43 |
#2 | |
MA
Rep Power: 6 |
Sorry I forgot to attach the figure. Here it is: https://drive.google.com/drive/folde...VxIKHYJCwx7oI7 |
February 4, 2023, 09:21 |
Turbulence CFD
anonymous
For velocity scale - you need to calc turb intensity (based on reynolds umber) , turb kinetic energy (based on intensity and bulk flow speed), dissipation rate (based on kinetic energy, intensity and Cu- assumed 0.09), take ratio of kinetic energy and dissipation gives time scale. Velocity scale is length scale (0.07 * duct width) / time scale. Equations are found after quick search online.
3D CFD simulation of propeller blade - Turbulent viscosity limited to viscosity ratio | Quentin_C | FLUENT | 1 | April 4, 2017 05:32 |
3D CFD simulation of propeller blade - Turbulent viscosity limited to viscosity ratio | Quentin_C | FLUENT | 0 | April 4, 2017 05:18 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Turbulent Boundary condition, viscosity ratio and length scale | Bollonga | FLUENT | 80 | February 16, 2013 12:06 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
