cant understand this point - Fourier No. in transient heat conduction |
August 13, 2020, 04:05 |
Rep Power: 5 |
hello everyone
in 1d transient conduction problem - why the results are different when i change the Fourier No. (Fo) although the time is the same for example : Fo=0.5 - i get these results after 301 sec 1000.000 724.375 448.750 448.750 448.750 724.375 1000.000 Fo=0.0083 - i get these results after 301 sec 1000.000 684.532 454.825 371.198 454.825 684.532 1000.000 |
August 17, 2020, 23:47 |
Chris DeGroot
I have no ideas what the numbers that you listed represent, but it is expected that changing the Fourier number would change the temperature field for a given time. This is because the Fourier number represents the ratio of diffusive energy transport to rate of storage/depletion.
August 18, 2020, 03:06 |
Lucky
Rep Power: 66 |
The Fourier number is the non-dimensional time-step for heat conduction problems, so of course the results will change.
problem in transient heat transfer of ground heat exchanger | teguhtf | FLUENT | 0 | April 23, 2020 05:46 |
Transient heat conduction computation time reduction | Mowgli | OpenFOAM | 0 | October 8, 2019 09:48 |
2d transient heat conduction (gauss seidel) | souha11 | Main CFD Forum | 0 | March 5, 2016 09:51 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
