Roe approximation for stiffed gas equation of state
Like Tree1Likes
  • 1 Post By Eifoehn4
Old   September 29, 2020, 10:02
Default Roe approximation for stiffed gas equation of state
nikkey is on a distinguished road
Good day,
I want to implement Euler equations finite volume scheme for compressible nonlinear liquid based on stiffed gas equation of state (EOS) of the form:
P=(\gamma-1)e \rho + \gamma P_c
where, P - pressure, \gamma - ratio of specific heats, e - internal energy, \rho - density, P_c - stiffness parameter.
I would like to use Roe approximate Riemann solver, the same way as discussed in the original Roe's paper. For it, I first need to calculate the Jacobian for Euler system. However, it seems that the Jacobian has the same form as for ideal gas EOS. Does this mean that I can use the same approach for stiffed gas EOS as for ideal gas EOS (same wave strength, right eigenvectors), with the only difference that Roe averages of speed of sound and enthalpy for stiffed gas EOS will be a bit different?
Thank you in advance!
nikkey is offline   Reply With Quote
Old   September 29, 2020, 12:43
Eifoehn4's Avatar
Eifoehn4 is on a distinguished road
Yes, there should be no difference as along as both sides of the Riemann problem consists of the same EOS.
Note that this is not the case for real equations of state.
nikkey likes this.
Check out my side project:
A multiphysics discontinuous Galerkin framework: Youtube, Gitlab.
Eifoehn4 is offline   Reply With Quote
Old   November 21, 2020, 22:36
sam
mczero57 is on a distinguished road
Hello Nikkey,
If both gamma and Pc are constants, then you are just adding a constant to the pressure and that should not change anything. Just make sure that this EOS makes sense thermodynamically - ie entropy and enthalpy, etc. are well defined.
Thanks
Sam
mczero57 is offline   Reply With Quote
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
Equation of state for water? jinwon park Main CFD Forum 2 December 20, 2007 07:32
continuity equation Rafal Main CFD Forum 4 November 29, 2006 09:27
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
Roe scheme for general equation of state zouchu Main CFD Forum 3 August 10, 2000 16:46
