Alfin Pohan
Rep Power: 5 ![]() |
Hello there!
I was making 2 domains inside a fluid domain and defined one of it as inlet and the other as outlet. But once i tried to running it, the flows didnt go out thru outlet as i defined before. I made 3 mm gap between drum and housing domain so the fluids could be able to moved into the drum and expectedly to go out to outlet. But its just hit the drum and nothing happened, do you guys think i miss some boundaries or my geometry is not correct at all? I attached a picture here. Last edited by Alfinmp; November 12, 2020 at 02:17. Reason: The picture i attached did not appeare |
Correct way to fix reverse flow at outlet | Dreoasteh | OpenFOAM Running, Solving & CFD | 14 | August 15, 2023 04:56 |
How to unserstand Correct boundary condition at outlet for incompressible flow? | aja1345 | FLUENT | 3 | July 16, 2018 12:12 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Reversed Flow in Outlet | Steve | FLUENT | 18 | March 30, 2013 07:50 |
Net mass flow inlet vs outlet | Nigui28 | FLUENT | 1 | August 12, 2011 10:09 |
