Openfoam, Laminar versus K epsilon versus kwSST
Old   November 13, 2020, 11:55
Default Openfoam, Laminar versus K epsilon versus kwSST
Bineet Mehra
bineet_aero is on a distinguished road
Hello All,
I did a simple conjugate heat transfer simulation using openfoam (chtMultiRegionFoam) for some electronic components being cooled by a liquid. Total heat duty to which the electronic comonents were subjected were around 200W.
Even though the Re was around 3500, i started with a laminar simulation. I did the enthalpy check ie mcp(Tout- Tin) for the fluid to compare with the 200 W i supplied. Since it was a steady simulation with no heat storage mcp(Tout- Tin) was almost equal to 200 W and i am happy.
Now i introduced Kepsilon model into picture. Again tried the balance, however this time Tout was 2 deg more than that in the laminar simulation hence the comparison between mcp(Tout- Tin) fluid with Q = 200W was not good.
Then i tried kwSST with all the setting same as inthe previous case, however this time, the simulation could not go through and i got a negative temperature error. Just to specify, for the moment, i am using wall functions to treat the BL in the turblent simulations.
Any idea/advice/input for such behavior ?
Thanks
bineet_aero is offline   Reply With Quote
chtmulitregionfoam, keplison, komega, laminar, openfoam
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
epsilon and K blowing up. sivakumar OpenFOAM Running, Solving & CFD 1 October 25, 2012 04:50
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
Difference between STAR Ed and Te to OpenFOAM epsilon and k michael OpenFOAM Running, Solving & CFD 0 April 7, 2006 10:22
