When the turbulent model theory is used to solve the turbulent boundary layer |
November 14, 2020, 13:47 |
Ashiq Ali
Rep Power: 5 |
layer, can the algebra stress model (ASM) be used? Why? |
November 16, 2020, 13:35 |
Lucky
Rep Power: 66 |
The algebraic stress model is a turbulence model. You're asking when a turbulence model is being used, if a turbulence model can be used.
If you're asking whether a turbulence model can be used on a turbulent boundary layer, the answer is it should or else it's not a good turbulence model. If you're asking whether the algebraic stress model is a good model for a turbulent boundary layer, the answer is it depends. It's a model, not the best one, your mileage will vary. |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
[snappyHexMesh] layer not added | Rasmusiwersen | OpenFOAM Meshing & Mesh Conversion | 1 | January 2, 2020 09:43 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Validity & transformation of boundary layer equations | Obad | Main CFD Forum | 2 | April 27, 2015 02:59 |
Turbulent Boundary Layer on a Flat Plate | Hoshang Garda | FLUENT | 1 | November 27, 2013 10:24 |
