Extrapolating the mean velocity profile function from Channel395 |
November 22, 2020, 20:43 |
Arijit Saha
Rep Power: 7 |
Hello CFDpros,
I am using Channel 395 case in Openfoam and sampling the time series data at a midplane surface which later I'm interested in using as an inlet to another channel flow. Also I'm using some other Inflow turbulence generation method like KSEC where I m trying to keep the mean velocity profile and standard deviation profile at the inlet similar to the Channel395 case. So, in this regard does anyone have any idea like how to figure out the profile functions from channel395 or any other idea on how I can feed the same profile? NOTE:- In KSEC method I cant simply sample the same velocity data from channel395 and feed it at inlet. |
Womersley velocity Profile - Bessel function terms | Rohini | FLUENT | 1 | January 8, 2019 10:25 |
atmBoundaryLayerInletVelocity - Velocity Profile not continuous through domain | sdfij6354 | OpenFOAM Running, Solving & CFD | 3 | July 26, 2017 16:16 |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
