November 15, 2023, 12:32 |
Conjugate heat transfer: thin solid
SMN
Rep Power: 16 |
I am simulating the heat transfer between a flow and thin solid. As you know mesh in the solid is problematic in the case of very thin wall, I can generate only one cell in the thickness direction). I would like to know if there is any way in CFX to treat the interface as a wall, as in Fluent where we can apply the solid properties (thickness and material) on a surface without the solid domain. thanks |
[Salome] Number of nodes for proper heat transfer in thin solid | mm66 | OpenFOAM Meshing & Mesh Conversion | 0 | January 21, 2020 15:10 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Algorithme choosing for solid part analysis of conjugate heat transfer | Anna Tian | Main CFD Forum | 4 | January 20, 2013 16:11 |
Conjugate Heat Transfer in rhoPisoTwinParcelFoam | jabecker | OpenFOAM | 0 | June 23, 2011 09:19 |
