Finite difference method for fourth order PDE |
February 14, 2021, 12:26 |
Box
Rep Power: 5 |
How can I solve this initial boundary problem?
WhatsApp Image 2021-02-14 at 20.58.08.jpeg Are my approximations right? WhatsApp Image 2021-02-14 at 23.18.58.jpeg it's the nonlinear mathematical model of the dynamics of a rotating drill string compressed at both ends by the longitudinal force N(x3, t) u2 - displacement of the center of bending of the cross-section of the bar along the x2 axe due to bending E = 2.1e11 # Pa - Young's modulus rho = 7800 # kg/м3 - density v = 0.28 # Poisson's ratio d1 = 0.12 # м - drill string inner diameter d2 = 0.2 # м - external diameter A = 2.01e-2 # Column cross-sectional area Ix1 = PI / 64. * (d2 ** 4 - d1 ** 4) # Ring section moment of inertia Omega = 0.33 # drill string angular velocity C1 = 0.01 # constant determining the rate of deviation of the drill string axis from the initial position in the Ox2x3 plane at the initial moment time. Thank you in advance Last edited by BoxQwerty; February 15, 2021 at 23:37. |
February 14, 2021, 14:23 |
Filippo Maria Denaro
Rep Power: 71 |
I don't know the physics described by this PDE, the problem is not only in a consistent discretization but also on the mathematical character of the equation. A second order in time PDE could be hyperbolic but I see also fourth order spatial terms. Central discretization in time and space is consistent but I don't know if it is also stable.
Then, also the BCs for this problem should be analysed. Have you some specific reference? |
February 15, 2021, 05:48 |
Box
Rep Power: 5 |
Material I have is all in Russian.
In short, it's the nonlinear mathematical model of the dynamics of a rotating drill string compressed at both ends by the longitudinal force N(x3, t) u2 - displacement of the center of bending of the cross-section of the bar along the x2 axe due to bending E = 2.1e11 # Pa - Young's modulus rho = 7800 # kg/м3 - density v = 0.28 # Poisson's ratio d1 = 0.12 # м - drill string inner diameter d2 = 0.2 # м - external diameter A = 2.01e-2 # Column cross-sectional area Ix1 = PI / 64. * (d2 ** 4 - d1 ** 4) # Ring section moment of inertia Omega = 0.33 # drill string angular velocity C1 = 0.01 # constant determining the rate of deviation of the drill string axis from the initial position in the Ox2x3 plane at the initial moment time. |
February 15, 2021, 05:49 |
Box
Rep Power: 5 |
In short it's the nonlinear mathematical model of the dynamics of a rotating drill string compressed at both ends by the longitudinal force N(x3, t) u2 - displacement of the center of bending of the cross-section of the bar along the x2 axe due to bending E = 2.1e11 # Pa - Young's modulus rho = 7800 # kg/м3 - density v = 0.28 # Poisson's ratio d1 = 0.12 # м - drill string inner diameter d2 = 0.2 # м - external diameter A = 2.01e-2 # Column cross-sectional area Ix1 = PI / 64. * (d2 ** 4 - d1 ** 4) # Ring section moment of inertia Omega = 0.33 # drill string angular velocity C1 = 0.01 # constant determining the rate of deviation of the drill string axis from the initial position in the Ox2x3 plane at the initial moment time. |
finite difference, numerical solution, pde |
Finite element method ANSYS CFX | tomd97 | CFX | 2 | April 4, 2018 04:10 |
Finite difference method | kaliramesh | FLUENT | 1 | January 16, 2014 12:55 |
Difference between first order and second order | msatrustegui | FLUENT | 2 | December 5, 2012 05:54 |
Finite volume method vs finite difference method? | superfool | Main CFD Forum | 4 | October 21, 2006 14:37 |
High order compact finite difference schemes | Mikhail | Main CFD Forum | 6 | August 5, 2003 10:36 |
