Determining flow type of natural convection in cylindrical cavity |
July 2, 2021, 09:13 |
Rep Power: 5 |
I'm just out of college and staring my career in CFD. I have a question regarding natural convection in closed cavities. How do I determine flow type for my CFD simulation? I know that we can judge flow type by Reynolds (Re) number in forced convection and Rayleigh (Ra) number, which is a product of Grashof (Gr) and Prandtld (Pr) numbers, in natural convection. However, only critical values of Ra that i've found is 10^9 for vertical plate cooling (found in Y.Cengel "Heat Transfer. A Practical Approach." as well as T.L Bergman et all "Fundamentals of Heat and Mass Transfer") and 10^6 for squared cavity (found here: https://www.researchgate.net/publica...nclosed_cavity). How do I proceed when my geometry is not one of those two. For example consider "cylinder in cylinder" cavity presented on the picture below: . I tried to find some resources with similar geometry and H/R ratio but I was not able to find anything. How then can judge character of my flow? Best Regards, Wojtek |
July 2, 2021, 11:20 |
Uwe Pilz
Rep Power: 15 |
I don't understand you case fully.
We have the natural convection, which mostly happens in a boundary layer (it is driven there). Do we have a rotation cylinder in a fixed surroundings or do we have a rotation cell?
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
July 8, 2021, 02:28 |
Rep Power: 5 |
It is simply a cylindrical heat source with gas layer of thickness R outside. No rotation, arrows are just to show where fluid flow is happening. I just provided an example - my question is more general: How to judge weather flow is turbulent or laminar in natural convection in cavities.
July 8, 2021, 08:02 |
Uwe Pilz
Rep Power: 15 |
I assume that you simulate temperature with the flow. Starting turbulence somewhere in the region means that you have a steep gradient of temperature: Laminar means you have mostly head conduction, a diffusion like process. In turbulence all is mixed and the process is convection dominated.
July 8, 2021, 08:29 |
Francisco
Rep Power: 8 |
Nevermind, I just re-re-read your question and you have found the article on convection-driven cavities...
This might be a starting point, since they simulate non-square cavities. However, you might have to dig deeper into bibliography to find out about transition itself. Also, keep in mind that this is a 2D study and not an axisymmetric one. |
July 10, 2021, 02:55 |
Rep Power: 5 |
Thanks for the replies and sources, i'll look into them
Mass flow rate issue | parthigcar | OpenFOAM Running, Solving & CFD | 2 | April 12, 2021 11:03 |
Instability in buoyantSimpleFoam | Avandri | OpenFOAM Running, Solving & CFD | 0 | August 7, 2020 16:13 |
Compression instead of expansion | EnricoDeFilippi | OpenFOAM Running, Solving & CFD | 1 | October 8, 2018 10:19 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
Divergent temperature in chtMultiRegion(Simple)Foam | akrasemann | OpenFOAM Running, Solving & CFD | 13 | March 24, 2014 02:54 |
