July 14, 2021, 08:16 |
UDF for heat pipe
Mohab Gad
I hope anyone could be able to help. Am trying to simulate heat pipe using fluent, when i used the built in Lee model i ve got non applicable result, so i had to use UDF for evaporation and condensation. However, when i load the UDF no errors occur, when i start to initialize i get the following error:
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () the udf used is attached. I need to know rather is there an error in the UDF formula or am not identifying it in the most proper way. Am using interpret method and identify the UDF in phase interaction under mass transfer for evaporation and condensation, also in source terms for boundary conditions i defined the energy UDF. |
Compiling and loading UDF using Batch | ALBATTROSS | FLUENT | 3 | May 20, 2019 21:50 |
UDF compiling error | Weiqiang Liu | FLUENT | 2 | November 21, 2018 09:36 |
Linking initial data and source terms from UDF to Fluent in simulating heat pipe | say2017 | Fluent UDF and Scheme Programming | 0 | October 20, 2017 12:35 |
Help UDF to Boundary Conditions in Closed Loop Pipe | Blader | Fluent UDF and Scheme Programming | 2 | May 14, 2012 09:48 |
UDF for fully developed turbulent pipe flow | Maged | FLUENT | 1 | June 11, 2005 10:37 |
