Finite Volume Method
Like Tree3Likes
  • 1 Post By LuckyTran
  • 1 Post By FMDenaro
Old   August 16, 2021, 05:50
Default Finite Volume Method
Mercurial
Techies is on a distinguished road
Hi guys,
I'm begginer to understand FVM, What is the different between the fluid element and fluid particle; rate and net rate ?
Thanks
Techies is offline   Reply With Quote
Old   August 16, 2021, 15:33
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
It's called net rate of flow because stuff can flow in and out of a fluid element at the same time in different places. But the overall amount determines whether the phi in the fluid element increases or decreases.
I'm not a fan of this word equation. Fluid element and particle are usually synonymous, they mean the same thing. It's better to just read the math symbols in this case. If you need help understanding the meaning of each term in the equation ask. Otherwise, don't get stuck on trying to grasp this poor presentation. I can't even see the equation but the fluid particle in this context refers to the material volume.
Techies likes this.
LuckyTran is offline   Reply With Quote
Old   August 16, 2021, 15:44
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Techies View Post
Hi guys,
Thanks
The textbook you're reading?
FMDenaro is offline   Reply With Quote
Old   August 17, 2021, 00:03
Mercurial
A Introduction to CFD, H K Versteeg and W Malalasekera
Old   August 17, 2021, 02:15
Mercurial
Thanks for your reply. I have other questions that is why do we divide momentum equation into 3 equations but not with continuity and energy ?
For pressure-velocity coupling, why have we 4 equations (1 continuity and 3 momentum) and 4 unknows (1 p, 3 velocity) instead of 6 equations and 6 unknows (3 pressure xyz and 3 velocity uvw)?
Thanks.
Old   August 17, 2021, 04:13
Lucky
Thanks.
It depends who you ask. The momentum equation is considered 1 vector equation or 3 equations in the x,y,z components. It depends only on whether you are talking about the full 3D velocity vector or the directional components of the velocity vector. Why? Some people just don't like to juggle with vectors and like to work in their x,y,z components.
Continuity is a scalar equation, so always it is 1 equation. Energy equation is also a scalar equation in temperature (or internal energy or enthalpy). There isn't a x,y,z component for a scalar. Pressure is also a scalar (1 variable).
So for p-v coupling, you will have either 2 equations (continuity & momentum) in 2 unknowns (pressure and your velocity vector) or 4 equations (continuity + 3 momentum equations) in 4 unknowns (pressure, & 3 velocity components). You never have 6, there is no such thing as pressure in x,y,z direction.
Techies likes this.
Old   August 17, 2021, 04:37
Mercurial
I gett it, thanks for helping.
Old   August 17, 2021, 04:38
Unfortunately, that textbook starts the presentation in a misleading way. They present first the differential equations while I suggest to start from the physical law expressed by the Reynolds theorem. The link between the lagrangian and eulerian representation is in the Eq.(2.40) you should consider as the starting equation for the FVM. Conservation principle, concept of flux and flow rates require the integral formulation.
Have a look also to the textbook of Ferziger, Peric, Street.
Techies likes this.
finite volume method and finite difference method harishkamat100 FLUENT 3 December 21, 2020 23:52
Finite element method ANSYS CFX tomd97 CFX 2 April 4, 2018 04:10
Mesh; wall function for element based finite volume method sheaker CFX 2 January 25, 2018 17:36
ALE in finite volume method littlelz Main CFD Forum 5 June 21, 2003 12:50
finite volume method for CFD analysis of 2D blunt body Aditya Vaze Main CFD Forum 1 January 19, 2000 13:55
