Fire dynamic simulator : Fuel density regarding
Old   September 7, 2021, 01:11
Default Fire dynamic simulator : Fuel density regarding
praveen
pv_cfd is on a distinguished road
hi all,
I am working on fires at different altitudes (reduced air pressures) and using Pyrosim interface. Used volume flow rate (area*vel) to specify the rate of flow.
I am using methane as fuel and the density of the fuel will also be less at higher altitudes.
My doubt is whether I need to use a mass flow rate inlet and reduced mass flow rate to accommodate the variation in density of fuel with altitude.
I have set the simulation parameters- reduced pressure and reduced oxygen fraction already.
Will FDS take this fuel density variation automatically if I specify a volumetric flow inlet?
pv_cfd is offline   Reply With Quote
fire dynamic simulator, fire dynamics simulations, fire simulation, pyrosim, reduced pressure
Fire and smoke modeling CFDST CFX 84 April 30, 2019 07:01
How to find density without having dynamic viscosity? ooo OpenFOAM Running, Solving & CFD 6 January 28, 2014 12:46
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 14:20
Variable Density Function ryzd FLUENT 1 August 25, 2011 14:16
Warning 097- AB Siemens 6 November 15, 2004 04:41
