pressure fluctuation when using timevaryingmappedfixedvalue boundary condition |
Not applicable
Rep Power: 7 ![]() |
Dear Fomer,
Recently I'm using the incompressible SADDES model in OF to do my study. The model is a cavity whose inlet variables are time-dependent and collected from another big model. The velocity, pressure gradient, and other turbulence variables are collected from the big model and given to be the inlet condition of the small model. The mesh of the model I'm simulating is the same as it in the big model. the small model is the final part of the big model, so their outlet BCs are the same. The boundary condition I'm using in small model velocity inlet: timeVaryingMappedFixedValue outlet: zerogradient pressure: inlet: timeVaryingMappedFixedgradient(developed by our team) outlet:fixed value: zero nusgs: inlet:timeVaryingMappedFixedgradient outlet:zerogradient nutilda: inlet: timeVaryingMappedFixedValue outlet: zerogradient The fvscheme and fvsolution are the same as the big one. I found the lift force of the cavity surface has some strange fluctuation and I don't know why. I have corrected the inlet velocity value to make sure the mass flow rate is constant. is it correct that specify velocity and pressure gradient at the inlet at the same time? Any Help Thanks. |
Appropriate pressure boundary condition in incompressible flow | lonelywing | OpenFOAM Running, Solving & CFD | 21 | June 6, 2022 09:44 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Total Pressure boundary condition in the OpenFOAM | dli | OpenFOAM Programming & Development | 1 | December 5, 2017 23:16 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
