November 17, 2021, 23:03 |
Could I try this simulation in my own PC
Ahmed Kamal Alnemr
Rep Power: 6 |
Hello, I am new student in CFD, thus I am reading research papers and try to simulate it in my own PC to just practice my skills, the question is could I run simulation on my own PC Dell G5 with processor i7 6 cores and RAM 16GP, the case is 3D cavity (Fuel-Air) mixing in supersonic combustion with total element on Ansys Mesh (17278118) ?
or this will be harmful simulation to my machine ? |
November 18, 2021, 02:41 |
Lucky
Rep Power: 66 |
Will it cause your PC to explode? Unlikely.
Depending on the number of transport variables needing to be stored though, I don't think you can run a 17 million cell case with only 16 GB of RAM. |
November 18, 2021, 03:27 |
Alex
Rep Power: 47 |
I would even go a bit further and say that not only will your PC not explode, it will also not take any damage from doing what it is supposed to do
So don't worry about that. PCs these days have protection mechanisms built-in. Limiting sustained power draw, reducing clock speeds when overheating... it is rather hard to damage components by just running regular software. As was already stated, the model is probably too large for 16GB RAM. If you just want to practice, you can run the same case with a coarser mesh. Maybe even try to figure out a more efficient meshing strategy that gets good results with fewer cells. |
mesh 3d |
Convergence Problem - Transient Simulation | gemxx | Main CFD Forum | 0 | July 15, 2018 09:36 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 05:28 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 02:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 03:16 |
