Energy Residuals Not Reducing
Old   March 5, 2022, 08:52
Unhappy Energy Residuals Not Reducing
Simranjeet Kaur
Simranjeet Kaur is on a distinguished road
Hi there,
I am currently running a coal combustion simulation in a tangential-fired boiler with the models below:
-Energy
- Turbulence (Realizable k-e)
- Radiation (P1)
- Species (Non premixed)
- Discrete Phase
I've ran the simulation for over 10000 iterations but the energy residuals are still at 10^-4 only. Im not sure if its suppose to take more iterations. The total nodes are about 300k.
Also, I've noticed that when i use P1, the solution diverges if I the URF is 1. The highest i can set it to is 0.7. Is this okay?
I also see plenty of messages as below:
Minimum PDF table enthalpy exceeded in 1126587 cells on zone 5.
Maximum PDF table enthalpy exceeded in 1283 cells on zone 5.
I tried adjusting the maximum heat loss fraction (changed it to 1) and minimum heat loss fraction (changed it to 1) as well but to no avail. I dont know if this is the issue causing my energy residuals to not decrease.
Apart from that, under the discrete phase model, am I required to set the Çustom Laws or leave it unchecked?
If anyone has experience solving these issues, i would truly appreciate your help. Thanks.
Simranjeet Kaur is offline   Reply With Quote
coal combustion, discrete phase, non-premixed
Energy balance in conjugative/ porous simulation; Domain Energy is greater than Input Vishnu_bharathi CFX 2 June 27, 2018 10:08
Comparing residuals of momentum and energy equation skarma FLUENT 4 November 25, 2017 22:03
Turbulence Kinetic Energy Residuals not converging gemxx STAR-CCM+ 4 May 4, 2017 02:41
on energy residuals domenicoBUFF FLUENT 0 February 4, 2013 12:10
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
