January 19, 2022, 08:41 |
Related to Wall Shear Stress calculation
Heer
Rep Power: 5 |
Hello!
I am working on a patient-specific geometry consisting of the aorta and coronary arteries. I want to break down the Wall Shear Stress into the tangential and the normal shear stress components. Is there a possible way to do that? I am interested in the tangential component in the direction of flow. Thanks in advance! |
January 19, 2022, 09:10 |
Rep Power: 18 |
Can you not simply use the surface normal and tangent vectors to resolve the components of the shear stress along those directions using the dot product?
January 19, 2022, 09:18 |
Heer
Rep Power: 5 |
While using CFD Post, I am getting a variable 'normal' but I am not sure how to obtain the tangential component? Should I obtain the tangential component through the normal component? I am not very clear about this, it would be great if you could elaborate on this?
Thank you in advance! |
January 19, 2022, 11:46 |
#4 | |
Filippo Maria Denaro
Rep Power: 71 |
Be careful, in 3D you have the unique normal direction but not a unique tangential one. if you have a pipe-shape that should be clear. |
March 8, 2022, 10:18 |
Heer
Rep Power: 5 |
How to obtain fluid shear stress (not only wall shear stress) in openFOAM | sourav90 | OpenFOAM Programming & Development | 8 | June 27, 2023 10:03 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Calculating the Wall Shear Stress Gradient over surface | 123catty456 | Main CFD Forum | 1 | October 1, 2012 22:27 |
shear stress scalar definitions? | Novak Elliott | CFX | 0 | April 6, 2003 01:45 |
What is the detail definition of wall shear stress | zjm | FLUENT | 0 | January 2, 2002 07:43 |
