Info on local time stepping
Old   October 8, 1998, 20:27
Default Info on local time stepping
Frank Muldoon
Can anyone point me to some information on local time stepping for solving the steady state compressible N-S equations
Old   October 9, 1998, 07:44
Default Re: Info on local time stepping
Heinz Wilkening
Ciao Frank,
from my experience when I made my diploma thesis, local time stepping means, that there is no common timestep in the hole computational domain, but each nodepoint has its own timestep, which is the maximum possible. eg. cfl = 1. depending on the solver used. But still you perform one advancestep for all nodes. You do not make for some nodes two or more timesteps when you do only one for others. Something like this might be usefull in a transient timeaccurate simulation.
As in the stady state du/dt gets zero, there isn't any error any more, because the solution gets independent on dt.
When I used local time steeping to the staty state solution I found it most simple (you save even to search for the minium timestep in the computational domain), and it was the most effective way to improve convergency to the stady state solution.
Ciao Heinz
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
local time stepping cfdbeginner Main CFD Forum 4 March 3, 2006 04:26
