How to selecting the turbulence specification method |
April 22, 2022, 07:09 |
Khairul
Rep Power: 4 |
Hello, how to choose the turbulence specification method
- my project specification - Sudden contraction 90* - 5/5 m/s inlet - Turbulence flow - 2D geometry In boundary condition, for inlet part How to choose turbulence specification method |
April 22, 2022, 08:50 |
Lucky
Rep Power: 66 |
It's just a matter of which parameters you actually know and find most convenient. At the end of the day, what actually gets specified is the values of your transport variables: k and epsilon, k and omega, and so on. If you want to learn how to do it the correct way, then choose k and epsilon (or omega, or whatever) and input these values directly. When you go and try to estimate k and epsilon, you'll find that you more-often-than-not use turbulence intensity and some type of length scale because these are more universal parameters that you can translate between different geometries very easily whereas k and epsilon are scale specific.
Error "elements not defined in..." | Davyd | OpenFOAM Pre-Processing | 4 | November 19, 2020 22:22 |
What is the reason not allowing to continue the simulation | Davyd | OpenFOAM Pre-Processing | 4 | June 6, 2020 05:20 |
simplifiedSiwek - error in calculating the position of a coal error | guitar_love_15 | OpenFOAM Running, Solving & CFD | 0 | November 4, 2018 04:06 |
hello Evry body please i want to used vof method and k-omega sst turbulence model fo | luca007 | FLUENT | 4 | February 20, 2017 09:17 |
Help Selecting Turbulence Model for VOF Problem | NavierIsStoked | FLUENT | 0 | November 1, 2013 11:27 |
