Boiling Curve
Old   May 26, 2022, 18:09
Default Boiling Curve
ABDELRAHMAN HOSNY
abdelhosny is on a distinguished road
Hello Everyone
I'm working on cooling of a hot plate using water jet numerically. I'm interested in plotting the boiling curve X-axis = delta T ( Tsurface-Tsaturated) / Y-axis =Heat flux. I tried doing it but I didn't get any results. I just want to make sure if I'm using the right formulas and parameters or not.
What i know:
T surface is the temperature of the top surface of the plate .
T saturated is 100 C
what about the Heat flux I know flunet calculates it but since the problem is 2d I get undefined value.
I hope I can get a response.
Thank you in advance.
abdelhosny is offline   Reply With Quote
boiling, convection, fluent, flux calculation, heat
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 07:58
gmshToFoam error erkampasha Main CFD Forum 1 March 22, 2021 13:52
OpenFOAM error Vinay Kumar V Main CFD Forum 0 February 20, 2020 09:17
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
