Cantera Python error
Old   May 25, 2022, 13:56
Default Cantera Python error
priyesh kakka
kakkapriyesh is on a distinguished road
Hi all,
I am running AMD system on UBUNTU 20.2 and I faced the following error after successfully installing Cantera via Conda
import cantera
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "/home/priyesh/anaconda3/envs/ct-env/lib/python3.9/site-packages/cantera/__init__.py", line 4, in <module>
from ._cantera import *
ImportError: libmkl_rt.so.2: cannot open shared object file: No such file or directory
I solved this issue by going to the cantera source code and changing "libmkl_rt.so.1" to "libmkl_rt.so.2"
I hope this helps.
kakkapriyesh is offline   Reply With Quote
Old   May 30, 2022, 16:26
Brent Skabelund
Mighty Boulder is on a distinguished road
Where did you find the libmkl_rt.so? I have not been able to locate it...
Mighty Boulder is offline   Reply With Quote
Old   May 31, 2022, 11:47
priyesh kakka
I think you will have to find the installed dir, for me I installed it through Conda, so the installed directory was in the conda environment. The error will also throw the path at which the directory is missing, go to that path and search for "libmkl" only and not the complete thing (because the file name might have numbers at the end).
Hope this helps
Old   January 30, 2023, 14:23
James
pdeforfree is on a distinguished road
Originally Posted by kakkapriyesh View Post
Hi all,
import cantera
I hope this helps.
I had the same issue, where the error was for missing libmkl_rt.so.2 while libmkl_rt.so.1 existed in my anaconda3/envs/cantera/lib folder. Rather than editing the Cantera source code, adding a soft symbolic link did the trick: ln -s libmkl_rt.so.1 libmkl_rt.so.2.
pdeforfree is offline   Reply With Quote
cantera, error, python
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
