Periodic boundary conditions for velocity in Staggered grids |
August 21, 2022, 04:45 |
Divyaprakash
Rep Power: 11 |
I am trying to implement periodic boundary conditions along the x -direction. So far I am getting error in the approach I am using. https://drive.google.com/file/d/1E_z...ew?usp=sharing I want to confirm If I have correctly implement the BCs. I am attaching an image which shows how I have implemented periodicity. The first grid corresponds to pressure. The second grid corresponds to u-velocity. The hatched lines indicate the periodic boundary. Can someone confirm if this correct or correct them if wrong. Last edited by Divyaprakash; August 21, 2022 at 04:46. Reason: image was not visible |
August 21, 2022, 06:36 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
August 21, 2022, 08:37 |
Divyaprakash
Rep Power: 11 |
The x velocity is forward staggered.
August 21, 2022, 09:09 |
Rep Power: 71 |
I used your sketch to show the correct staggered colocation for all the u components superimposed to the pressure colocation.
However, you seems to show walls at the BCs, thus you cannot use periodicity. |
August 21, 2022, 09:36 |
Divyaprakash
Rep Power: 11 |
Thank you so much for your time. Actually the ends are not walls. I used hatched lines, just to indicate boundaries. I am trying to simulate a 2D case with the top and bottom walls moving and the left and right boundaries periodic.
Can you please tell me in terms of the notations that you used in the figure, how may I apply the pressure and velocity boundary conditions? I have been stuck at this problem for quite long. Last edited by Divyaprakash; August 21, 2022 at 09:38. Reason: More details |
August 21, 2022, 11:30 |
#6 | |
Rep Power: 71 |
The pressure notation you wrote is correct. The u-velocity periodicity needs to set u1=u6. |
August 21, 2022, 12:27 |
Divyaprakash
Rep Power: 11 |
August 21, 2022, 12:31 |
Rep Power: 71 |
You have to compute the equation for one of them
August 21, 2022, 12:44 |
#9 |
Divyaprakash
Rep Power: 11 |
Thank you so much. I'll try to implement it. Just one more question. I have seen in many places the BC being implemented as follows. how to implement periodic bc on a staggered grid Would this work too? Based on above I had implemented the BC in my original figure. |
periodic bc, staggered grid |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Can I achieve better convergence? | sheaker | CFX | 12 | September 19, 2019 15:36 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
PEMFC module + multiple periodic boundary conditions | vkrastev | FLUENT | 2 | December 22, 2014 04:15 |
