2d planar simulation setting
Old   August 27, 2022, 15:31
Default 2d planar simulation setting
Chenxi
FutureCX is on a distinguished road
Hi, I am doing the VOF simulation in a T-shape pipe as shown in the pic. Now, I'd like to simplify the simulation as a 2d planar model along the pipe center line. But I am confused how to set the refernce value as the diameter for each pipe is different. Besides, how should I set the boundary condition for this 2d planar simulation? I used the velocity inlet and pressure outlet for 3d simulation at the pipe ends. Should I use the velocity inlet bc with the same value for 2d simulation or replace velocity inlet with massflow inlet? Thanks in advance.
FutureCX is offline   Reply With Quote
Help with setting up BC for Pressure in stirred tank multiphase simulation MazenDraw OpenFOAM Pre-Processing 1 June 5, 2021 03:52
Setting up 3D simulation for external gear pump 310toumad FLUENT 2 February 5, 2019 09:12
fvscheme setting in Actuator Line simulation gxy200992243 OpenFOAM Running, Solving & CFD 0 June 18, 2014 10:23
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Setting up Flow around a Wing Simulation help Atella CFX 3 January 3, 2010 11:51
