Viscosity of molten steel
Old   August 9, 2000, 12:09
Default Viscosity of molten steel
Pete
I'm looking for the viscosity of molten steel, preferably as a function of temperature. Any help appreciated.
Old   August 17, 2000, 16:46
Default Re: Viscosity of molten steel
Dr Strangelove
Look for Smithell's Metals Reference book.
Also, look for papers by B G Thomas, et al. on simulations of steel casting, etc. As is frequently the case, someone else has done legwork that you can put to good use.
Since turbulence is likely in many situations of interest for molten steel processing, what imprecision you suffer in the viscosity won't be as influential as the uncertainty in your turbulence model, which will also serve to smother the difficulty you'll have in obtaining values for the thermal conductivity of molten steel, too.
Good luck.
Eulerian Modeling: Frictional Viscosity Help meangreen FLUENT 1 January 25, 2018 15:13
Power - Law Viscosity Model for Polymers NickolasPl OpenFOAM 2 August 12, 2011 08:26
Melting Aluminum by molten Stell leff Main CFD Forum 0 May 17, 2011 04:12
kinematic viscosity at diff temperatures,pressures Mecobio Main CFD Forum 0 November 7, 2005 12:55
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
