Numerical code on Prandtl Meyer Expansion Wave using Maccormack technique |
January 13, 2023, 02:13 |
TAMILNADU
%From JD Anderson textbook for Computational Fluid Dynamics Chap 8,using
%Maccormack technique of space marching PM wave expansion is solved %numerically x=0; spacestep=0; y=linspace(0,1,41);%This is the computational y domain Co=0.5;%Courant no prompt=input('Enter the coeffcient for artificial viscosity:'); Cy=prompt; digits(4); for i=1:41 %Boundary Conditions for x=0 is defined here M(i)=2; p(i)=101325; T(i)=286; D(i)=1.225; a=(1.4*287*T(i))^0.5; u(i)=a*2; v(i)=0; F1(i)=D(i)*u(i); F2(i)=D(i)*(u(i)^2)+p(i); F3(i)=F1(i)*v(i); F4(i)=3.5*p(i)*u(i)+(F1(i)*(u(i)^2)/2); G1(i)=0; G2(i)=0; G3(i)=p(i); G4(i)=0; end net=[transpose(D) transpose(u) transpose(v) transpose(p) transpose(T) transpose(M)]; disp(net); while(spacestep<50) if x>10 h=40+(x-10)*tan(deg2rad(5.352));%Height of the domain which is a function of x def=5.352;%Deflection Angle else h=40; def=0; end %Loop for calculating the marching step size of the domain across x %direction for i=1:41 MA=rad2deg(asin(1/M(i))); pos=abs(tan(deg2rad(5.352+MA))); neg=abs(tan(deg2rad(5.352-MA))); a1=max(pos,neg); delX(i)=Co*h*0.025/a1; end delX; step=min(delX);%Finding the minimum value of step size of the 41 grid pts along y axis [dF1_dx,dF2_dx,dF3_dx,dF4_dx,F1_p,F2_p,F3_p,F4_p,p_ p,G1_p,G2_p,G3_p,G4_p]=predictor(F1,F2,F3,F4,G1,G2,G3,G4,def,h,Cy,step,p ,y); [dF1c_dx,dF2c_dx,dF3c_dx,dF4c_dx,SF1c,SF2c,SF3c,SF4 c]=corrector(F1_p,F2_p,F3_p,F4_p,p_p,G1_p,G2_p,G3_p, G4_p,h,Cy,y,def); dF1avg_dx=(dF1_dx+dF1c_dx)/2; dF2avg_dx=(dF2_dx+dF2c_dx)/2; dF3avg_dx=(dF3_dx+dF3c_dx)/2; dF4avg_dx=(dF4_dx+dF4c_dx)/2; for i=1:41 F1(i)=F1(i)+SF1c(i)+dF1avg_dx(i)*step;%F1,F2,F3,F4 are the flux terms required to be found F2(i)=F2(i)+SF2c(i)+dF2avg_dx(i)*step; F3(i)=F3(i)+SF3c(i)+dF3avg_dx(i)*step; F4(i)=F4(i)+SF4c(i)+dF4avg_dx(i)*step; A=((F3(i)^2)/(2*F1(i)))-F4(i); B=3.5*F1(i)*F2(i); C=-3*(F1(i)^3); D(i)=(-B+(B^2-4*A*C)^0.5)/(2*A);%Here the decoding of primitive variables are done u(i)=F1(i)/D(i); v(i)=F3(i)/F1(i); p(i)=F2(i)-F1(i)*u(i); T(i)=p(i)/(D(i)*287); magV=(u(i)^2+v(i)^2)^0.5; M(i)=magV/((1.4*287*T(i))^0.5); G1(i)=D(i)*v(i);%G1,G2,G3,G4 are the source terms G2(i)=F3(i); G3(i)=D(i)*(v(i)^2)+p(i); G4(i)=3.5*p(i)*v(i)+F1(i)*(v(i)^2)/2; end v %Here the Abbot Boundary Condition has been employed for the wall grid point if x>10 ang=rad2deg(atan(abs(v(1))/u(1))); Rot_ang=def-ang; else ang=rad2deg(atan(v(1)/u(1))); Rot_ang=ang; end M a=M(1); pmf=prandtlmeyer(a); pmactual=pmf+Rot_ang; act=Mach(1.4,pmactual); act_p=p(1)*((1+0.2*a^2)/(1+0.2*act^2))^3.5; act_T=T(1)*(1+0.2*a^2)/(1+0.2*act^2); D(1)=act_p/(287*act_T); p(1)=act_p; T(1)=act_T; v(1)=-u(1)*tan(deg2rad(def)); M(1)=act; %M(1)=((u(1)^2+v(1)^2)^0.5)/((1.4*287*T(1))^0.5); F1(1)=D(1)*u(1); F2(1)=D(1)*(u(1)^2)+p(1); F3(1)=F1(1)*v(1); F4(1)=3.5*p(1)*u(1)+F1(1)*(u(1)^2)/2; G1(1)=D(1)*v(1); G2(1)=F3(1); G3(1)=D(1)*(v(1)^2)+p(1); G4(1)=3.5*p(1)*v(1)+F1(1)*(v(1)^2)/2; M %net=[transpose(D) transpose(u) transpose(v) transpose(p) transpose(T) transpose(M)]; %disp(net); x=x+step; spacestep=spacestep+1; end function [dF1_dx,dF2_dx,dF3_dx,dF4_dx,F1_p,F2_p,F3_p,F4_p,p_ p,G1_p,G2_p,G3_p,G4_p] = predictor(F1,F2,F3,F4,G1,G2,G3,G4,def,h,Cy,step,p, y) for i=1:41 deta_dx=(1-y(i))*tan(deg2rad(def))/h; if i~=41 dF1_dy=(F1(i)-F1(i+1))/0.025; dG1_dy=(G1(i)-G1(i+1))/0.025; dF1_dx(i)=deta_dx*dF1_dy+(dG1_dy/h); dF2_dy=(F2(i)-F2(i+1))/0.025; dG2_dy=(G2(i)-G2(i+1))/0.025; dF2_dx(i)=deta_dx*dF2_dy+(dG2_dy/h); dF3_dy=(F3(i)-F3(i+1))/0.025; dG3_dy=(G3(i)-G3(i+1))/0.025; dF3_dx(i)=deta_dx*dF3_dy+(dG3_dy/h); dF4_dy=(F4(i)-F4(i+1))/0.025; dG4_dy=(G4(i)-G4(i+1))/0.025; dF4_dx(i)=deta_dx*dF4_dy+(dG4_dy/h); else dF1_dy=(F1(i-1)-F1(i))/0.025; dG1_dy=(G1(i-1)-G1(i))/0.025; dF1_dx(i)=deta_dx*dF1_dy+(dG1_dy/h); dF2_dy=(F2(i-1)-F2(i))/0.025; dG2_dy=(G2(i-1)-G2(i))/0.025; dF2_dx(i)=deta_dx*dF2_dy+(dG2_dy/h); dF3_dy=(F3(i-1)-F3(i))/0.025; dG3_dy=(G3(i-1)-G3(i))/0.025; dF3_dx(i)=deta_dx*dF3_dy+(dG3_dy/h); dF4_dy=(F4(i-1)-F4(i))/0.025; dG4_dy=(G4(i-1)-G4(i))/0.025; dF4_dx(i)=deta_dx*dF4_dy+(dG4_dy/h); end if i==1 || i==41 SF1=0; SF2=0; SF3=0; SF4=0; else %These are the artificial viscosity terms for predictor step SF1=(abs(p(i+1)-2*p(i)+p(i-1))*Cy*(F1(i+1)-2*F1(i)+F1(i-1)))/(p(i+1)+2*p(i)+p(i-1)); SF2=(abs(p(i+1)-2*p(i)+p(i-1))*Cy*(F2(i+1)-2*F2(i)+F2(i-1)))/(p(i+1)+2*p(i)+p(i-1)); SF3=(abs(p(i+1)-2*p(i)+p(i-1))*Cy*(F3(i+1)-2*F3(i)+F3(i-1)))/(p(i+1)+2*p(i)+p(i-1)); SF4=(abs(p(i+1)-2*p(i)+p(i-1))*Cy*(F4(i+1)-2*F4(i)+F4(i-1)))/(p(i+1)+2*p(i)+p(i-1)); end F1_p(i)=F1(i)+SF1+dF1_dx(i)*step; F2_p(i)=F2(i)+SF2+dF2_dx(i)*step; F3_p(i)=F3(i)+SF3+dF3_dx(i)*step; F4_p(i)=F4(i)+SF4+dF4_dx(i)*step; A=((F3_p(i)^2)/(2*F1_p(i)))-F4_p(i); B=3.5*F1_p(i)*F2_p(i); C=-3*(F1_p(i)^3); D_p(i)=(-B+(B^2-4*A*C)^0.5)/(2*A); u_p(i)=F1_p(i)/D_p(i); % v_p(i)=F3_p(i)/F1_p(i); p_p(i)=F2_p(i)-F1_p(i)*u_p(i); %T_p(i)=p_p(i)/(D_p(i)*287); G1_p(i)=D_p(i)*F3_p(i)/F1_p(i); G2_p(i)=F3_p(i); G3_p(i)=D_p(i)*(F3_p(i)/F1_p(i))^2+F2_p(i)-(F1_p(i)^2/D_p(i)); te=F3_p(i)/F1_p(i); G4_p(i)=3.5*(F2_p(i)-(F1_p(i)^2/D_p(i)))*te+0.5*D_p(i)*te*((F1_p(i)/D_p(i))^2+te^2); end end function [dF1c_dx,dF2c_dx,dF3c_dx,dF4c_dx,SF1c,SF2c,SF3c,SF4 c] = corrector(F1_p,F2_p,F3_p,F4_p,p_p,G1_p,G2_p,G3_p,G 4_p,h,Cy,y,def) for i=1:41 deta_dx=(1-y(i))*tan(deg2rad(def))/h; if i>1 dF1_dy=(F1_p(i-1)-F1_p(i))/0.025; dG1_dy=(G1_p(i-1)-G1_p(i))/0.025; dF1c_dx(i)=deta_dx*dF1_dy+(dG1_dy/h); dF2_dy=(F2_p(i-1)-F2_p(i))/0.025; dG2_dy=(G2_p(i-1)-G1_p(i))/0.025; dF2c_dx(i)=deta_dx*dF2_dy+(dG2_dy/h); dF3_dy=(F3_p(i-1)-F3_p(i))/0.025; dG3_dy=(G3_p(i-1)-G3_p(i))/0.025; dF3c_dx(i)=deta_dx*dF3_dy+(dG3_dy/h); dF4_dy=(F4_p(i-1)-F4_p(i))/0.025; dG4_dy=(G4_p(i-1)-G4_p(i))/0.025; dF4c_dx(i)=deta_dx*dF4_dy+(dG4_dy/h); else dF1_dy=(F1_p(i)-F1_p(i+1))/0.025; dG1_dy=(G1_p(i)-G1_p(i+1))/0.025; dF1c_dx(i)=deta_dx*dF1_dy+(dG1_dy/h); dF2_dy=(F2_p(i)-F2_p(i+1))/0.025; dG2_dy=(G2_p(i)-G1_p(i+1))/0.025; dF2c_dx(i)=deta_dx*dF2_dy+(dG2_dy/h); dF3_dy=(F3_p(i)-F3_p(i+1))/0.025; dG3_dy=(G3_p(i)-G3_p(i+1))/0.025; dF3c_dx(i)=deta_dx*dF3_dy+(dG3_dy/h); dF4_dy=(F4_p(i)-F4_p(i+1))/0.025; dG4_dy=(G4_p(i)-G4_p(i+1))/0.025; dF4c_dx(i)=deta_dx*dF4_dy+(dG4_dy/h); end SF1c(1)=0; SF2c(1)=0; SF3c(1)=0; SF4c(1)=0; for i=2:40 SF1c(i)=(abs(p_p(i+1)-2*p_p(i)+p_p(i-1))*Cy*(F1_p(i+1)-2*F1_p(i)+F1_p(i-1)))/(p_p(i+1)+2*p_p(i)+p_p(i-1)); SF2c(i)=(abs(p_p(i+1)-2*p_p(i)+p_p(i-1))*Cy*(F2_p(i+1)-2*F2_p(i)+F2_p(i-1)))/(p_p(i+1)+2*p_p(i)+p_p(i-1)); SF3c(i)=(abs(p_p(i+1)-2*p_p(i)+p_p(i-1))*Cy*(F3_p(i+1)-2*F3_p(i)+F3_p(i-1)))/(p_p(i+1)+2*p_p(i)+p_p(i-1)); SF4c(i)=(abs(p_p(i+1)-2*p_p(i)+p_p(i-1))*Cy*(F4_p(i+1)-2*F4_p(i)+F4_p(i-1)))/(p_p(i+1)+2*p_p(i)+p_p(i-1)); end SF1c(41)=0; SF2c(41)=0; SF3c(41)=0; SF4c(41)=0; %dF1c_dx(41)=0; %dF2c_dx(41)=0; %dF3c_dx(41)=0; %dF4c_dx(41)=0; end end function [pm]=prandtlmeyer(m) c=(1.4+1)/(1.4-1); p2=m^2 -1; p3=rad2deg(atan(sqrt(p2/c))); p4=rad2deg(atan(sqrt(p2))); pm=sqrt(c)*p3-p4; end function [t]=Mach(g,p) b=2.9; a=1.1; precision=0.0000001; c=(g+1)/(g-1); %To find mach,bisection method has been employed p2=a^2 -1; r2=((a+b)/2)^2-1; p3=rad2deg(atan(sqrt(p2/c))); r3=rad2deg(atan(sqrt(r2/c))); r4=rad2deg(atan(sqrt(r2))); p4=rad2deg(atan(sqrt(p2))); pm=sqrt(c)*p3-p4; rm=sqrt(c)*r3-r4; zero1=pm-p; zero2=rm-p; while((b-a)/2>precision) if zero1*zero2<=0 b=(a+b)/2; else a=(a+b)/2; end p2=a^2 -1; r2=((a+b)/2)^2-1; p3=rad2deg(atan(sqrt(p2/c))); r3=rad2deg(atan(sqrt(r2/c))); r4=rad2deg(atan(sqrt(r2))); p4=rad2deg(atan(sqrt(p2))); pm=sqrt(c)*p3-p4; rm=sqrt(c)*r3-r4; zero1=pm-p; zero2=rm-p; end t=(a+b)/2; end |
please help?, what is the error |
[waves2Foam] Waves2Foam Related Topics | ngj | OpenFOAM Community Contributions | 660 | August 20, 2018 12:39 |
Matlab code for the numerical solution of a Prandtl-Meyer expansion wave flow field | ivan_CFD | Main CFD Forum | 4 | March 8, 2012 15:17 |
Solutions of Nozzle Flows by MacCormack Technique | worasit | Main CFD Forum | 5 | September 29, 2003 11:38 |
Prandtl-Meyer Expansion Wave | Maciej Matyka | Main CFD Forum | 0 | March 13, 2003 19:55 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
