January 12, 2023, 08:40 |
Density of dry air vs. humid air?
Steve Lainé
Rep Power: 3 |
I have a question around correctly simulating the air with different densities. It would make sense to me that dry air at the same atmospheric pressure would have a lower density than humid at the same atmospheric pressure. What densities should I use for example for 50% humidity vs. 80% humidity for a HVAC supply case?
January 12, 2023, 14:40 |
Lucky
Rep Power: 66 |
Use Dalton's law of partial pressures. Your wet density is:
or Obviously there is two or more steps not shown to convert relative humidity into the partial pressure. As mentioned already, since the molecular weight of water (2 hydrogens and 1 oxygen) is less than the other molecular compounds (N-2, O-2, and CO2 are all heavier than 1-Oxygen), the density of wet air is less than dry air. If not for this property, the sky would rain fire instead of rain; and it did, many eons ago. |
February 16, 2023, 05:18 |
Steve Lainé
Rep Power: 3 |
Fog formation from phase change of humid air | gartz89 | FLUENT | 4 | January 20, 2021 20:01 |
How to model condensation of humid air in ANSYS FLUENT? | raveesh | FLUENT | 0 | August 5, 2020 06:11 |
modeling condensation in humid air... | a.mashayekh | FLUENT | 9 | May 7, 2015 19:12 |
Density of air for calculating the mass flow rate from Darcy's law | Hermano | Main CFD Forum | 0 | August 22, 2011 11:17 |
moist air density | rafat | Main CFD Forum | 5 | June 13, 2001 21:36 |
