July 4, 2021, 10:41 |
Turbulence Prandtl Number Prt
Mercurial
Rep Power: 5 |
Hi everyone,
I'm simulating heat transfer and i have some questions. What is Turbulence Prandtl Number and how to specify it ? What is different between using Prt and no using Prt? Thanks all |
July 4, 2021, 18:00 |
Lucky
Rep Power: 66 |
When you do Reynolds Averaging, turbulence stresses appear that need to be modeled with closure models. For the momentum equations, it ends up being a model for the turbulent viscosity. For the energy equation, you also need a model for the turbulent conductivity (or turbulent thermal diffusivity).
Usually, we calculate the turbulent conductivity from the turbulent viscosity by the turbulent Prandtl number the same way you can calculate conductivity from molecular viscosity if you prescribe a Prandtl number. If you are doing RANS and simulating heat transfer, you'll almost always have a turbulent Prandtl number unless have your own special turbulent heat flux model. The value of the turbulent Prandtl number is flow dependent but it typically is in the range of 0.8-0.9 (but not always and it is not universal). In general, it needs its own model. |
November 20, 2021, 07:51 |
Thanks for your answer, Do you know where I can change the constant Prt to my own mod
Outside North America
Rep Power: 4 |
April 5, 2023, 07:33 |
Marc Ricart
Rep Power: 3 |
April 5, 2023, 09:29 |
Lucky
Rep Power: 66 |
What this means? Give an example?
Turbulent Prandtl number is a property of the flow, not a fluid property. It's like asking whether velocity depends if it is air or water. Well yes it does, but also, what is even the question? |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
Customize the Prandtl number in the k-epsilon mode | ClydeL | FLUENT | 5 | November 20, 2021 22:11 |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
