How to run openfoam simulation through external hard drive |
May 12, 2023, 12:50 |
West Midlands
Rep Power: 3 |
hello,
I am low on space on my desktop but I have a 5TB external hard drive, how can I run my openfoam simulation from an external hard drive if I am using ubuntu ? |
May 12, 2023, 13:17 |
Lucky
Rep Power: 66 |
Assuming you can mount the hard-drive.... just do it? Where are you having trouble? You can run OpenFOAM from any directory and that includes other hard drives. If you can copy and paste a file onto your HD, then you can foam it.
May 13, 2023, 04:31 |
West Midlands
Rep Power: 3 |
I am running home directory through Ubuntu, so do I need to transfer the directory into the external hard drive
May 13, 2023, 09:40 |
Lucky
Rep Power: 66 |
I am very confused. Have you used OpenFOAM before? How do you use it?
Is it not the case that you open a terminal/kernel in an arbitrary directory and type for example blockMesh snappyHexMesh simpleFoam etc How do you do it? Because these can be done anywhere. |
May 16, 2023, 11:20 |
K
Rep Power: 3 |
Dear R786,
Yes, usually we run OpenFOAM in Ubuntu in the home/OpenFOAM/<username>v<versionnumber>/run directory, but you don't have to. Just mount the external disk, and use any directory in there that you would like. Just keep in mind that you may deal with some latency if OpenFOAM is not installed on a different disk. |
May 16, 2023, 12:09 |
Lucky
Rep Power: 66 |
Clarification: the lag is due to your external drive where your case is stored (potentially) being connected to a slower bus (e.g. USB) instead of a high speed bus and foam needing to read and write files to this snail drive, not because of foam not being installed on the external drive.
Foam should be installed in the location most convenient for you. It can be your home drive, your external drive, a cloud drive, a usb stick, heck even a floppy disk. Of course, you can install foam on the external disk if you so choose. |
Openfoam v1906 on arm64 ubuntu eoan, wont run in any directory | EternalSeekerX | OpenFOAM Bugs | 1 | September 11, 2020 14:06 |
[OpenFOAM.com] Installing OpenFOAM on secondary drive | CronusX | OpenFOAM Installation | 4 | June 25, 2020 05:04 |
[OpenFOAM.com] Installing OpenFOAM on secondary drive | CronusX | OpenFOAM Installation | 0 | June 21, 2020 16:14 |
How to run unsteady simulation in OpenFOAM? | usman89 | OpenFOAM | 1 | August 12, 2016 10:26 |
Can't get data from OpenFoam to external solver using externalCoupled | perry | OpenFOAM Running, Solving & CFD | 4 | May 26, 2014 08:09 |
