May 17, 2023, 13:12 |
Aerofoil Wake Length for Isotropy
Rep Power: 4 |
I have been doing some DDES simulations in fluent over a wing. I have a close refinement region but would like to ensure the length is enough for reasonable isotropy in the wake to get captured by the subgrid model. I am struggling to find resources online on this topic, and have very limited computing power available to run an independence study on this. Is there a way to know how long the refinement region should extend? Cheers |
May 17, 2023, 19:51 |
Lucky
Rep Power: 66 |
The short answer is make sure you have 10 pts (or x pts) across the wake.
The long answer is you need to estimate the taylor microscale at every location and determine where that scale grows larger than your refinement. The faster way of doing this is to eyeball the size of the wake at each region and get the Reynolds number. The most likely outcome though is you'll find out you always need refinement downstream of the wake (within the wake) but laterally you can coarsen the grid closer to the freestream. |
May 17, 2023, 23:57 |
#3 | |
Rep Power: 4 |
When you say 10 points, could you please elaborate? 10 grid points seems very small... This is a 3d simulation by the way. |
May 18, 2023, 01:47 |
Lucky
Rep Power: 66 |
See Von Neumann's elephant.
Typically in CFD we say 10 points across a feature, although the rule of 10 gets broken by a lot of people, very often. It sounds like you are ready to break this rule already without even attempting the problem. Yes 10 points can be very small. That is my point (pun intended). You can come up with all the complicated theories you want, but at the end of the day, you quickly find out that you are constrained by much simpler rules. I've only mentioned 10 points and already you complain that it is too much... I'm willing to compromise to 8 points. |
May 18, 2023, 02:07 |
#5 | |
Rep Power: 4 |
Apologies I should have worded that differently. What I meant was that 10 points seems like a very small number. To clarify is that 10 cells? Meaning the wake only needs 10 cells worth of spacing to capture it? I'm not fully understanding. |
May 18, 2023, 02:30 |
Lucky
Rep Power: 66 |
10 pts is good enough for DNS. Across the wake means across the (thin) shear layer thickness. You repeat this at every streamwise location. 10 points across a feature is a statement of resolution.
It definitely does not mean 10 cells. |
Wake length behind a circular cylinder | Corleone84 | STAR-CCM+ | 6 | December 31, 2015 01:10 |
Cylinder (or other) wake length as function of Reynolds | jbsp | Main CFD Forum | 0 | November 4, 2015 20:53 |
Wake Length calculation in FLUENT | mahi007 | FLUENT | 2 | March 14, 2012 04:51 |
wake centerline length &wake length | Fred | Main CFD Forum | 0 | July 27, 2007 01:20 |
how does the wake length depend on turbulence | bf | Main CFD Forum | 1 | April 13, 2006 01:55 |
