negative inlet temperature for axisymmetric nozzle flow using rhoCentralFoam |
May 3, 2023, 08:59 |
Baptiste
Rep Power: 3 |
I have been trying to simulate a very simple nozzle flow with OpenFOAM flow in the past weeks. I have tried many different parameters and hypotheses, changing them only one at a time, but everyone one them has led to the same result: the simulation crashes with the error message "negative temperature inlet T0=-XXXK". The domain I am considering is a short straight section followed by a simple convergent-divergent with straight walls sections. To take advantage of the geometry, I am solving the flow with axisymmetric BC. My domain is then a simple wedge - of less than 5°. The domain is meshed with gmsh, creating a structured hexahedral mesh with grading from the center to the walls (growth ratio < 0.95). A grading is also applied from the inlet to the throat; after the throat, the mesh size is constant. rhoCentralFoam is used as a density-based solver and different turbulent models have been tried - k-eps, RNG k-eps, k-omega-SST. The courant number is set to Co<0.2. Boundary conditions are set as follow:
I am using CO2 in supercritical conditions as a fluid. I want to use a perfect gas model in the first place. Thus, my thermophysical properties as are follow: Code:
thermoType { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } mixture { // normalised gas specie { nMoles 1; molWeight 44.01; } thermodynamics { Cp 2327; Hf 0; } transport { mu 1.444e-5; Pr 1.5; } } My fvSchemes is set as follow: Code:
fluxScheme Kurganov; ddtSchemes { default Euler; } gradSchemes { default Gauss linear; limited cellLimited Gauss linear 1; } divSchemes { default none; div(phi,U) Gauss linearUpwind limited; div(phi,e) Gauss linearUpwind limited; div(phi,K) Gauss linearUpwind limited; turbulence Gauss linearUpwind limited; div(phi,epsilon) $turbulence; div(phi,k) $turbulence; div(phi,omega) $turbulence; div(phiv,p) Gauss linearUpwind limited; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; div(tauMC) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; reconstruct(rho) vanLeer; reconstruct(U) vanLeerV; reconstruct(T) vanLeer; } snGradSchemes { default corrected; } wallDist { method meshWave; } Code:
solvers { p { solver PCG; preconditioner DIC; tolerance 1e-08; relTol 0.01; } pFinal { $p; relTol 0; } "rho.*" { $p; tolerance 1e-05; relTol 0; } "(omega|U|e|h|k|epsilon).*" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-08; relTol 0.01; } } Parameters that I tried to modify:
note: When solving in 2D - 3D mesh, 1 cell wide with empty BC - the simulation converges with k-omegaSST turbulence model. All the other models make the simulation diverge (same error). I am open to any discussion about my simulation. Please don't hesitate to ask for more information. Best. |
May 3, 2023, 09:37 |
Baptiste
Rep Power: 3 |
In addition, please find attached pictures of the mesh I am using.
I also want to mention that I tried tu implement limitTemperature with fvOptions. However, it led me to the same "negative inlet temperature" error. |
May 9, 2023, 04:08 |
rhoCentralFoam negative inlet temperature
Baptiste
Rep Power: 3 |
By any chance, does anyone have any idea or insight ?
Best |
May 16, 2023, 11:14 |
Can someone answer to this post ?
Baptiste
Rep Power: 3 |
Is there a way to get people to see this post ? I know that multiple post for the same probleme is not allowed.
Best. |
May 16, 2023, 11:18 |
K
Rep Power: 3 |
OpenFOAM is not so good at importing meshes from other softwares. The negative temp at the inlet could be caused by misaligned normals. Check in gmsh that your normals are all pointing the correct direction.
May 16, 2023, 11:38 |
Baptiste
Rep Power: 3 |
You think this issue could come from bad normals ? The fact that the simulation runs for a long time before it crashes doesn't exclude this hypothesis ?
May 16, 2023, 12:55 |
Joern Beilke
Rep Power: 20 |
Just have a look at this tutorial:
https://github.com/unicfdlab/hybridC...ivergingNozzle It uses pimpleCentralFoam but might help. |
June 8, 2023, 03:05 |
Solution
Baptiste
Rep Power: 3 |
If anyone encounter a similar solution: I solved it by using setFields to initialize de fields in the domain.
The issue was that with the domain being initialized at 1bar and the inlet being at 91bar, it creates a shock in the convergent right at the beginning of the simulation. This shock propagates but unfortunately cannot be damped and creates a divergence when reaching the throat. By simply initializing the domain to highest pressures, and with a jump of pressure AFTER the throat, the simulation converged. |
June 8, 2023, 10:35 |
#9 | |
Lucky
Rep Power: 66 |
I want to go back to something
However, I do applaud you for updating your own post and confirming that initialization errors are still a common occurrence in 2023 and will likely continue to be a pain point for CFDers for the foreseeable future. |
June 13, 2023, 10:22 |
#10 | |
Baptiste
Rep Power: 3 |
convergence, openfoam2212, rhocentralfoam |
SU2 incompressible laminar flow | mkulcsar | SU2 | 3 | April 30, 2023 22:59 |
Total pressure and mass flow boundary condition at inlet | bscphil | OpenFOAM Pre-Processing | 3 | July 9, 2017 14:39 |
Mass flow inlet with given temperature | taalf | SU2 | 3 | October 15, 2015 14:25 |
Turbulent Intesity Inlet and outlet cavitating flow in Nozzle | SPH_CFD | FLUENT | 2 | April 29, 2015 08:51 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
