July 12, 2023, 05:05 |
Sloshing Problem
Adriana Pinto
Hello, I am using ANSYS Fluent to study sloshing inside a tank with baffles.
I did the simulation on the tank without baffles and I had no problems, but now when I insert the tank with baffles it gives me lots of errors and then it gives a floating point. One of the errors says it is Divergence detected in AMG solver: k Divergence detected in AMG solver: epsilon Error at host: floating point exception I believe that the error is because of the mesh. I am doing the mesh in ANSYS mechanical and I am using the option of adaptive sizing. I believe that this is what is causing problems because when I don't use it the simulation does not give me an error. Thus, I would like to know if in a simulation of this type where I am using VOF is necessary to use adaptive sizing. Furthermore, is adaptative sizing the same as adaptive meshing? Also, my continuity residuals are very high, what can it be? I hope somebody can help me. I have already tried some solutions but none seems to be working. Thank you very much for your attention. |
ansys, fluent, sloshing tank |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
Is COMSOL Multi Physics is suitable to solve complex flow problem? | steve lee | COMSOL | 8 | January 5, 2023 02:31 |
Mesh& steptime independant: conduction-convection problem | Fati1 | Main CFD Forum | 1 | October 28, 2018 13:52 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
