Inlet velocity becomes entire domain velocity
Old   July 4, 2023, 12:34
Default Inlet velocity becomes entire domain velocity
Tarık Yaman
dord is on a distinguished road
I was working on 2-way fsi analysis. I am trying to simulate the model in figure-1 (google drive). I wanted to validate the results in section 3.1.2 of the article titled "Computation of fluid–structure interaction on lightweight structures".
However, I am getting an error due to a sudden pressure effect on the plate.
Looking at the contours, I thought it would be because the inlet velocity was suddenly the velocity of the entire domain.
To eliminate this situation, I set the inlet velocity to 0 for the first 5 time steps and 1 m/s for the next steps.
I set up another analysis to try the results and again faced the same issue.
I want the flow to travel a distance that will be proportional to the velocity value from the inlet to the outlet. For example, if my inlet velocity is 1m/s, after 0.1 second I want the flow to move 0.1 meters. Is this possible?
You can access all settings and contour pictures from the link : https://drive.google.com/drive/folde...ER?usp=sharing
Thanks for be interested.
dord is offline   Reply With Quote
initialization, inlet velocity, patch, transient
Atmospheric BCs for domain with a single boundary serving as both the inlet & outlet Newtonian OpenFOAM Running, Solving & CFD 0 July 21, 2022 14:07
Making fluid velocity zero in the inlet of domain nived FLUENT 4 May 28, 2018 09:40
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
patching velocity profile to the inlet face of domain vasuaero1988 Fluent UDF and Scheme Programming 1 September 29, 2010 03:49
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
