July 3, 2023, 12:14 |
Boundary Conditions for lid-driven cavity
Rep Power: 2 |
does someone know the boundary conditions for the turbulence model of Spalart-Allmaras (SA) for a lid-driven cavity boundary value problem? I did not find any thesis or paper where it is explained. In general, the variable of the SA equation is set to zero at walls and three up to five times the kinematic viscosity at the inlet. Therefore, I wonder if I must set the variable of the SA to zero or not. Thank you |
July 4, 2023, 15:56 |
Lucky
Rep Power: 66 |
You don't find publications because it is an art, not a science. The 5 times viscosity corresponds to the very very very turbulent inflow. If you want a laminar inflow then you want to set it to 0. Except some implementations are unstable with a 0 nutilda inlet and you must specify a slightly positive number that isn't zero that stays laminar and doesn't blow up. Now because it is an art, make sure you also don't tell anyone else what number you used XD.
July 10, 2023, 05:15 |
#3 | |
Rep Power: 2 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
